pacesetters came in finally
got my pacesetters cant believe how good they are built.thickest flange ive ever seen on a header.very nice product.just have to wait on my ecu to get back from being tuned to put them on.any tips on installing or do they slide right in?
Mine went in piece of cake. Keep an eye on the dipstick tube, can be a pain in the *** on some cars (took hours on mine, must never have been out). Might have to trim the block tab (tough to describe but you'll know exactly what I mean when you try and put the header in, should it not fit). Other than that, went in easy as hell I was very satisfied with my purchase. Good luck.
-J
-J
Originally Posted by navyblueSS
They should slide right in. I didn't have to remove or cut on anything to get them in. Just make sure you get the car high enough in the air and you should have no problems.
-J
Originally Posted by greysteel_M6
Word of advice Replace the plugs! It's soooo easy with the headers off. Also you might need a hacksaw to cut that tab off on the driver's side.
I didn't have to cut or bend anything. They slid in very EZ..if I didn't hold them up they would fall out on the floor..had to get the GF to lay under the car and hold them till I got some of the bolts started .. got over 100 K miles on the ones in the car with no problems ... a good value
