Best coolant
Old 02-07-2007, 03:07 PM
Detoxx03's Avatar
Default Best coolant
What is the best coolant to put in a 2002 trans am?
Old 02-07-2007, 08:07 PM
sk8co's Avatar
dude its coolant.....
Old 02-07-2007, 08:16 PM
FU_I_AM_UltraZ's Avatar
dex... the green stuff will eventually eat away at the aluminum. that's why they GM switched over.
Old 02-07-2007, 08:35 PM
Detoxx03's Avatar
thanks
Old 02-07-2007, 09:03 PM
Flawless02SS's Avatar
I'd stay with Dex
Old 02-07-2007, 09:08 PM
Turbo LS1 SS's Avatar
never really thought much into the coolent itself, but a nice little trick is to add a tablespoon of DAWN dish soap to it. works as a nice wetter. seriously
Old 02-07-2007, 09:16 PM
dlandsvZ28's Avatar
If you are starting out with a complete new system - radiator and motor - IMO use Evans after a rebuild.
The long haulers get upwards to a million miles with the stuff - it lasts and lasts. Up front cost is more with Evans- keep your car and change every three years - Evans is cheaper. I hear you can buy Evans at John Deere dealerships cheaper.
I use Dexcool - keep the caps on and don't frequently expose DexCool to air and it won't gum like you see it do around the overflow cap and radiator cap if you keep exposing the stuff to air.
I can't switch to Evans because it doesn't like my Meziere electric water pump.
Old 02-07-2007, 11:14 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
This thread will slowly become a pissing match. Honestly. The manual from the factory says Dex. I will let you decide what my answer is to this.
Old 02-08-2007, 08:34 AM
68birdls1's Avatar
this is my second ls1 and i am using the mix with any brand or make stuff. i used the same stuff on my other ls1 as well.
Old 02-08-2007, 08:54 AM
Ragtop 99's Avatar
If you are having cooling problems, moderate your mix to use the most possible water without risking freezing. Moving to 70% distilled water, 30% DexCool and a bottle of purple ice or water wetter will help keep summer temps down if that is a problem.
Old 02-08-2007, 08:57 AM
billyjo's Avatar
I've read that Evans is the way to go also, I'm planning on giving it a try.
Bill
Old 02-08-2007, 09:06 AM
i think buying Evans is a gimic. why do they want you to ONLY use their crap with their water pumps... stay with 50/50 distilled water and dex and add a bottle of purple ice or water wetter. i use that on both my cars in my signature! never over heating problems in FL summer!! EVER!!!
Old 02-08-2007, 09:22 AM
TXZ28LS1's Avatar
word!! DEX COOl to keep your LS1 COOL!!
Old 02-14-2007, 09:49 AM
(deep, deep voice) E-YEH!!!!
Old 02-14-2007, 10:23 AM
99WS7's Avatar
the regular green stuff imo will work fine...I dont see it eating the aluminum drastically
Old 02-14-2007, 01:23 PM
SSmokin99's Avatar
Where do you get the "Dex" coolant? I don't even know how to change my coolant
Old 02-14-2007, 01:36 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I've been able to find Dexcool at Advance Auto and Auto Zone...it is what I use in mine along with distilled water. Keeps the car cool, and that's all I can ask.
Old 02-14-2007, 01:51 PM
TheLS1Kid's Avatar
i use the predilluted 50/50 mix green stuff from advance autoparts. works great.
Old 02-14-2007, 02:33 PM
RUDE SS's Avatar
If you mix the dex with green stuff you will run into trouble. Gaskets etc will rot. Green stuff has a shorter life span then dex cool also. I say stick to the dex cool; gm made it for their motors so stick with it.
Old 02-14-2007, 02:39 PM
TheLS1Kid's Avatar
agreed, but if you want to use the green, just make sure you flush the system.
Quick Reply: Best coolant
