intake info
intake info
i ran into this thing on ws6store.com and i was wondering about a lil more info about it??? how much hp gains and throttle response thanks!!!
heres the link:http://www.ws6project.com/user_stor/...2997f3faa7be0f
that link is just the top shell only, you would also have to buy the lower and middle piece also.
that is the whole thing that you would need
hp gains depend on amount of mods you have, but on stock engine, probably 10-15
I've got the F.A.S.T. 78mm and pretty happy with it, did feel a difference but then after every mod you think there is a difference anyway, I dont have any numbers. Was running SD and did run leaner with this fitted, therefore it helped more air enter the engine.
Not too sure if the F.A.S.T. 90mm with 90mm throttle body offerers much inprovement over the 78mm, but if buying that then you have the extra expence of another TB.
I'd say go with the 78mm. It does help, but how much... I cant tell ya.
