Would you spend a couple bills on a new MAF?
Old 02-12-2007, 11:27 AM
fasttagurl's Avatar
Default Would you spend a couple bills on a new MAF?
Now, I do not know if 10-15 hp is really worth $300-$500! Running the stock MAF (78mm) with a 90mm FAST intake/TB seems okay, but does changing it to a full 90mm set-up matter that much? Since it will measure more air coming in, does this small mod require additional tuning? Weigh in with experience or facts please! (BTW, car does not utilize forced induction!)
Old 02-12-2007, 12:15 PM
That's what she said...
TheBlurLS1's Avatar
It's not worth it until it becomes a restriction, which it isn't until 450-500rwhp N/A.
Swapping out to an 85mm GM unit (descreened truck, 'vette, or z06) can be done but you do need to have some tuning work. The computer has a MAF table that it uses to translate the MAF's signal into airflow. You can get a z06 MAF $130 or so from SDPC, then have LG throw the new table in for it. You'll need some couplers and stuff to put it together with though.
I'd be interested in seeing how much you pick up from it, it would be helpful for other members in the future.
HAMRHEAD's Avatar
No need to mess with the stocker. Some have but most don't. The stock flows just fine and you don't have to worry about any tuning issues. I've ran a 90/90 setup with the stocker and there wasn't an issue.
Old 02-12-2007, 12:56 PM
lsx24's Avatar
Would I spend a couple bills on a larger MAF? No, not until I had at least all the boltons. Do I think it causes a restriction even in a bolton configuration? Yes.
Old 02-12-2007, 01:01 PM
BADFNZ's Avatar
Get the 85mm truck MAF off Ebay for $40 like I did. Then get the 5 pin to 3 pin adapter from Casper Electronics for $25. Now you have a brand new OEM MAF that works for $65. It'll run without tuning but some tweaking should be done to get the most out of it.
Old 02-12-2007, 01:04 PM
staringback05's Avatar
BLUR hit it right on the head, unless your making a higher amount of hp you dont need to change it, however when the time comes, you dont need a name brand aftermarket MAF....most are just truck MAFs with a different resistor and a namebrand.....
Old 02-12-2007, 01:05 PM
lsx24's Avatar
How can you say that will run without tuning?
If you run a Z06 or Truck MAF without calibration, you ARE going to need to tune it to run properly.
Old 02-12-2007, 01:32 PM
BADFNZ's Avatar
Which is what I said. The car will run, but you'll need tuning.
Old 02-12-2007, 02:29 PM
Cop Car's Avatar
yes i would... if i already had all 126 cars i want and have a huge house and garage.
stock MAF or SD tune, nothing else !
Old 02-12-2007, 03:11 PM
98dirtybird's Avatar
Not to hijack. But, What if you baought the car used and it had a desrceened maf, all the free mods, and the car does weird things( trip check engine codes for o2 sensors that i replaced) oh and has the stage 1 jet module; would it be then worth it to geta stocker with screen, or upgrade?
Old 02-12-2007, 05:47 PM
Assman's Avatar
A descreened MAF wouldn't cause any problems dirtybird. Sounds like something else to me.
Old 02-13-2007, 02:21 AM
playtoy's Avatar
Hears what happened to my motor with a descreened mass air. Get one with a screen and put it on.
http://i167.photobucket.com/albums/u...y/100_0489.jpg
Old 02-13-2007, 02:30 AM
TheBlurLS1's Avatar
I'd like to know how a descreend MAF can cause that?
Only thing I can imagine is you removed the screen, then placed it inside one of the cylinders, along with 1/4 stick of dynamite.
Old 02-13-2007, 03:53 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Sounds pretty much what I was thinking.
Old 02-13-2007, 04:52 PM
TheSilverOne's Avatar
actually descreening a MAF on an A$ car would cause idle problems
i agree
Old 02-13-2007, 05:01 PM
5_02ls1's Avatar
leave it alone, i stupidly ported mine removed screen.well it ran good for about 10mi then went all to hell.luckily i got a stock one on ebay for 50$.
PLAYTOY were you even using an airfilter? the screen is there to straighten airflow,its not a secondary airfilter
Old 02-13-2007, 05:33 PM
NHRAFORMULA00's Avatar
my car has run just fine with a descreened maf for the last 3 years! now go figure
Old 02-13-2007, 06:37 PM
dpw41285's Avatar
i dont understand how removing the sceen can do that to a piston
Old 02-13-2007, 07:01 PM
ULTIMATEORANGESS's Avatar
i went with an SLP MAF when i added my FAST and NWTB. i figured why not since i was changing everything else.
Old 02-13-2007, 08:11 PM
Assman's Avatar
Maybe he didn't put an air filter in??? I would also like to know...
