Finally got around to doing an air lid...
aside from SFC's, LCA and PHR, this is the first thing done to my car as far as anything under the hood is concerned, and the first thing I've actually done myself (I can't weld, and I paid somebody else to do the lca's/phr because i don't have a lift :o )
I must say, for all I've seen about how long it takes, it took maybe 20 minutes after all is said and done... only took about 3 to get the MAF out of the stock lid, and 30 seconds or so for the IAT, and another 20 seconds for the air tube... all in all, 100% successful mod, and after having the car 6000 miles, I can certainly tell a difference in it's attitude .... of course, having the SS hood, I realized that there was a lot more junk in the paper filter that I had than I probably needed, so I used a K&N filter since it came with my lid ... all popped right in, no rubbing, no other issues... I should have done it far sooner than I had, because it had been sitting in my bedroom for who knows how long (4 months or so I bet) .... I was going to start doing my ripper shifter, but the little screw on my e-brake handle is stripped and I didn't feel like ******* around with it much .... but that's next once I find a screw that will fit it (any suggestions? )
the only thing bad that I had noticed, is that there is a seal on the stock airbox that looks like an oval... it looked shredded, and all of the bits and pieces ended up on the MAF screen (mesh looking thing) so I assume that wasn't making my car any happier either... anyone else ever run into that when changing out the stock air lid?
will try to get pics of it later, but not sure if my camera is charged or not.
now i just have to decide on exhaust vs. shocks/swaybars (and brakes)
i still have my catback to put on but I want to do headers/y as well...
unfortunately, i need brakes, and really think I should replace my shocks and swaybars because the bushings on them all are cracked to hell and about to come off in pieces they're so dry
That's what she said...
Everyone has to start somewhere, good luck on future mods!
I've never removed my e-brake handle, and I've had that damn center console out at least 20 times. You just remove all you can, then pop the little clicker with a screwdriver so the handle will go vertical. Main console will slide right off of it.
Originally Posted by Ripper415
intestering choice doing suspension before performance. unless you auto cross id say do more performance before you do more suspension.
people seem to do some things backwards sometimes.... honestly, in knowing what the tolerances for the stock components are ahead of time, there are just some things to do first ... the rear suspension, shocks, springs if you like them, and sway bars tend to be the weaker links ...
not saying that i'd not like to do the performance, I'm just doing what makes more sense to me in the long run...
granted, a lid, a catback, and even headers/y-pipe are on the list (I don't have headers/y-pipe just yet), but now that I've got the lid on, and the GMMG awaiting install.... I can go either way. I'd love to be the person with the money to do heads/cam right off the bat, and sure, I could have skipped my catback that I got at a GP rate, my sfc's, adjustable phr and lca's, my shifter and even the air lid, to go that route...
but thats just me.... few things at a time here and there, my car is a daily driver, and I've got preservation in mind, preventive maintenance, and even regularly schedule maintenance (like brakes, shocks, etc) .... just doing what I can
I love a load of power, but experience and reading others' experiences, leads me to believe there are many things that should come first before wanting to put down 500hp and having nothing to back it up
Originally Posted by orangeapeel
<--------- Cam, then bolt-ons.
i want to save for headers/y-pipe ... but realistically, I need to do the brakes and shocks/struts before anything else, then sways, then maybe look into the headers/y
after that, anything is game... but I have a feeling, I'll be buying major front suspension parts and then dropping everything up front when I do heads/cam so I can just do it out of the car, since i'll be doing a tubular k-member/a-arms and the wonderful world of poly engine mounts...
basically means, long term funding for long term part storage
for the parking brake, that screw is sometimes a rivet. i lost the screw one day putting the slp shifter in my sisters car and called the local gm dealership and f-bodymotorsports and both never heard of a screw being used for the handle that they were riveted in. i have an 02 Z and my sister has a 02 WS6, her's had a screw and mine has a rivet, go figure...
f
or brakes, i'd go with brembo drilled rotors. i use them (yes a lil pricey) and the lasted 40k miles before getting cut. and use hawk pads with them.
for the lca and phr, you could've jacked the rear up and done it yourself and saved $$$.
Strano Sway bars make a world of difference in handling. So will Konis, but they're not that great for drag racing. PHR, LCAs, poly motor mounts, sway bars, shocks, are all good handling upgrades.
who says I'm just going to be drag racing?
my stock shocks weren't properly cared for by the first owner, the bushings have all basically dried up and are shot now
