Kooks ORY issue
Kooks ORY issue
I put a set of Kooks headers and an ORY on my car a few months ago and have had a ton of issues trying to stop the banging/rattling/etc...
When I installed the system, I had hell getting everything to fit (Kooks headers, Kooks ORY and the SLP center exit exhaust that was an option on 2002 SSs). The headers went in fine, but the y-pipe just wasn't cooperating in lining up with everything. I ended up taking my car up to a local exhaust shop and working with the guy for over an hour to get it set up without cutting/modifying the headers/ypipe. End result was that we got it done, but it was very close to the driver's floor and driveshaft tunnel.
While driving the car with the resulting setup, one of the primaries on the driver side was rattling against the k-member - it only did this on right turns. The Y, on the other hand, would bang all the time under acceleration on both the floor and the tunnel. It banged hard enough that it would set off the knock sensor and pull timing out of the car...
Not acceptable, so on to my next steps:
I notched and filed down a small section of the k-member to alleviate the rattle on right turns. Now for the Y... I purchased the Mufflex hanger for the Y, tried it in various configurations. No luck. I have loosened and adjusted the brackets 5 times now and still can't get it to keep from hitting the floor, although I don't think it is contacting the tunnel anymore.
Is there an issue with the fit of the Y and the '02 center-exit SLP exhaust? Possible that the headers are not angled as they should be (I had never heard of anyone having to file their k-member with these headers)? The entire reason I went with Kooks was because of all the good stories I read about fit and installation ease...that makes me now.
With spring quickly approaching, any help anyone can provide would be greatly appreciated. This is driving me crazy...
Thanks for the help.
i had problems getting my y-pipe to fit as well. Mine sits real close to the floor boards i think as well. But from what i can tell its not hitting the floor at all on hard launches i have to wait till summer to be able to tell tho. i don't drive the car int he snow. if you have access to a lift can you see anything that would be rubbing?
Originally Posted by WS6RAMAIR79904
Thanks For The Heads Up. Good Thing I Read This In Time, I Was Ordering Kooks Lt Headers And The Ory But Looks Like Im Going With Qtp After All.
YUP!!! thats why i went with kooks too! Longbeach and i had a bitch off a time puting in my driver side header!!! and i mean it, we where getting mad and pissed off, but at the end it went in and the fitment of the headers and Y made it all worth it at the end. sure it does hit alitle bit when i mash on it but thats to be expected.
Please don't take this post as being negative or a bash on Kooks - that wasn't my point at all. I am just trying to get some input from others that may have had some of the same headaches.
I went with Kooks because the fitment seemed to be the best at the time. I have installed or helped install just about every header that has been made for the LS1 F-bodies and the Kooks headers fit great. If I was getting a new set tomorrow, I would get the Kooks again.
I honestly think that something is amiss with the Y in this case (either it was bent at the warehouse, during shipping, something).
As far as seeing what is rubbing - I have had the car in the air about 7 times in total at this point. The only place it is hitting is the driver's side floorpan. It is not rubbing, but banging. It hits under light acceleration (read: 1/3 throttle) and absolutely slams under full throttle.
I can't adjust it anymore without cutting/rewelding. I can't get it any lower than it is. Everything piece of exhaust under the car is locked solid with each other, there is no more adjustability that I can find. This isn't my daily driver, so I'm not worried about ground clearance - I have literally tried hanging from the Y to get more clearance, it just won't do it.
BTW George - I tried calling you earlier this afternoon but you were in a meeting. Feel free to give me a call in the morning (whomever answered your extension took my name and number). If I don't hear from you I'll give you a ring around lunch time.
