Which FAST intake for me?
Old 02-15-2007, 05:22 PM
14 Second Truck Club
Hemi Killer's Avatar
Default Which FAST intake for me?
I keep debating and feel like I'll be loosing a little bit either way I go. I feel like if I go with the 78mm, I'll be leaving some power on the table. Then, I feel like if I go with the 90mm, I'll be leaving some driveability on the table. With my mods (383 LS1/Full Bolt-ons/Full exhaust w/ cats) and truck (Daily Driver, 250-350 miles a week) which one would guys get? I'm gonna be getting one from Vengence new and ported. I just don't want to loose any low-end, like 3000 rpms and under. Then, just gain above 5000 rpms.
Old 02-15-2007, 05:25 PM
brad8266's Avatar
90/90 FTW, a 78 will be kind of choking a 383.
Old 02-15-2007, 05:30 PM
black01_WS6's Avatar
get the 90 hands down. I wouldn't even consider getting a 78 with your setup.
Old 02-15-2007, 06:25 PM
1997bird's Avatar
https://ls1tech.com/forums/advanced-engineering-tech/631476-can-you-over-throttlebody-efi-motor.html
Old 02-15-2007, 09:27 PM
So, I should be okay with the 90/90 set-up, considering my very mild cam/head set-up? What's another alternative to the FAST 90mm Throttle body? I heard the 90mm FAST ones suck and have problems. BTW, how many cfm is the stock (75mm), 78mm, and 90mm throttle bodies?
Also, do you car guys have to modify anything when you swap over to one of these intakes or does it bolt on exactly like the LS6? I'm asking because I know what I need to do the LS6 intake swap, just not sure about the FAST intake swap on a truck. Thanks!
Old 02-15-2007, 11:36 PM
Also, what bolts are used on the intake?
Old 02-24-2007, 02:00 PM
ttt...
Old 02-24-2007, 02:05 PM
slt200mph's Avatar
90/90 is the only way to go with a 383 motor..the 78mm will be very close to a LS6 intake .... the Nick Williams 90 mm throttle body is the best on the market ..
Old 02-24-2007, 02:17 PM
Just curious, how would the LS6 do compared to the 90/90 in the lower rpms? Like under 3500 rpms?
Old 02-24-2007, 05:34 PM
transaman98's Avatar
Kinda off subject, but hasn't FAST supposedly fixed the problems they were having with their 90mm tb? I havn't had any problems with mine.
Old 02-24-2007, 05:37 PM
pdd
pdd's Avatar
90mm fast-hands down
