NGK TR6 with H/C engine? Why not?
Old 02-15-2007, 05:23 PM
V8er's Avatar
Default NGK TR6 with H/C engine? Why not?
The old spark plug rule of thumb was one heat range colder for every 60 additional HP. A strong H/C 346ci LSX engine makes around 450rwhp which is close to 200HP more than a stock LS1. Why wouldn't we want to use the TR6 plugs in place of the standard heat range TR55 version? What possible disadvantage(s) would the colder plugs have? The colder plugs should help to pull more heat from the combustion chamber.
Old 02-15-2007, 05:26 PM
brad8266's Avatar
Run the TR6 with that setup, **** I ran them on my DD 346 with no fouling or idle issues.
Old 02-15-2007, 05:28 PM
TORCHD 02 TA's Avatar
Its a colder heat range plug than the TR55, but not due to a smaller gap. The physical design of the plug is what determines how much heat is dissipatates not the gap.
Old 02-15-2007, 05:30 PM
98Camarod's Avatar
I run TR6's too for the occasional nitrous shot, my mods are in my sig.
Old 02-15-2007, 05:44 PM
V8er's Avatar
I understand that and I wasn't ever discussing the gap size, just the heat range of the TR55 vs the TR6.
Unless the car is driven at light loads in artic temps why not use the TR6 in 400rwhp+ cars?
The reason I asked this question is because all I ever see being suggested on this board is the TR55 and never the TR6 unless it is a NOS car.
Old 02-15-2007, 05:46 PM
brad8266's Avatar
sounds familiar.
Old 02-15-2007, 05:47 PM
98Camarod's Avatar
Actually I am a liar, I changed the TR6's out and put in Autolite 103's same heat range though. The only difference is you can buy these at walmart.
Old 02-15-2007, 05:49 PM
brad8266's Avatar
Some people here just think that the rule in stone is if you spray then TR6 and if you are NA then TR55.
You got it right man, with the added power you want a colder plug since the increase in cylinder pressure will generate more heat which needs to go somewhere. The colder plug will get rid of that extra heat.
Old 02-15-2007, 05:50 PM
c5_ls1_6spd's Avatar
Im making over 450 and using TR55s also. No problems here with fouling or sputtering, etc.
Old 02-15-2007, 05:53 PM
brad8266's Avatar
Thats because you are using 55's, the TR6's are known for fouling in stock/mildy modded applications, although it never happened to me.
V8er's Avatar
By this same logic a 1.75" exhaust should be fine if you are making 450rwhp with it on the car
No doubt your TR55s are working but would TR6s be better?
Old 02-15-2007, 06:08 PM
brad8266's Avatar
why would TR6s be better?
Old 02-15-2007, 06:10 PM
brad8266's Avatar
Because 55's get too hot with the increased cylinder pressures that come from high HP. Once they become hot enough they can preignite the fuel.
Old 02-15-2007, 06:21 PM
Originally Posted by brad8266
sounds familiar.
was waiting to see if ya caught that
Old 02-16-2007, 12:30 PM
V8er's Avatar
I am going to install a set of TR6s and report back on how they perform.
Old 02-16-2007, 01:09 PM
TheLS1Kid's Avatar
I have a H/C 346ci LS1 and i use TR6 plugs gapped at .035. Runs great.
