solid motor mounts?
Old 02-19-2007, 05:11 PM
C Murda's Avatar
Default solid motor mounts?
i like the idea of having my motor solid but i am wondering if these are a good idea for big power? not that i am at this level but 1000lbs/ft of torque? the thing im worried about is a hard pull and snapping the solid mounts from the tq twist of the motor. can this happen or am i just over paranoid?
Old 02-19-2007, 10:15 PM
3.4camaro's Avatar
absolutely not. you will not snap solid motor mounts. you should be more worried about rubber mounts. solid mounts are more durable and rigid(hence "solid").
Old 02-19-2007, 10:36 PM
That's what she said...
TheBlurLS1's Avatar
You'll rip the bolts out of the block before you break a solid motor mount. You've got two noids....... (paranoid....)
Old 02-19-2007, 11:16 PM
texasreb18's Avatar
why not polyurethane motor mounts? ive gone thru 2 stock mmounts and the poly ones are holding up fine
Old 02-19-2007, 11:35 PM
Coy
Coy's Avatar
I have the Spohn solids, and they are NOT gonna break.
Old 02-19-2007, 11:36 PM
Go Topless's Avatar
I had solid mounts on my LT1 for a month, I had to replace them with poly mounts because the rattling and shaking is unbearable in a daily driver(IMO). If it is a track car or a weekend warrior and you are putting down a ton of power then it may make sense, but if it is a DD, I would go with poly.
Old 02-20-2007, 01:24 AM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
Hey,...........anyone got some good advise on how to swap em out since we're on the subject. I'm think'n about swap'n em out at the same time I'm throw'n on the LTs.
Old 02-20-2007, 01:37 AM
TheBlurLS1's Avatar
Pull exhaust out, jack up motor with phone book between jack and oilpan, unbolt motor mounts form block/k-member, then install new ones. Leave bolts loose untill they are all in.
Old 02-20-2007, 01:43 AM
staringback05's Avatar
PHONE BOOK......FTMFW
Old 02-20-2007, 02:28 AM
TheBlurLS1's Avatar
It works badass. Doesn't scuff anything, evenly distributes the load, gives you some extra height, and doesn't bash your freaking skull in if it falls off the jack while you're laying beside it.
I'm a driveway mechanic like you wouldn't believe....
Here's a pic from installing my buddies Kooks....
Old 02-20-2007, 09:24 AM
FU_I_AM_UltraZ's Avatar
i agree! i have a pair from energy suspension. i had solid mounts on my race car (in my signature) and the poly mounts fell smoother on corners b/c they GIVE a LITTLE and are mucho better than rubber mount and bushings.
Old 02-20-2007, 10:53 AM
lsx24's Avatar
I highly recommend poly motor mounts. They stiffen up the structure just enough, without inducing tons of NVH for a daily driver. Solid mounts are going to vibrate like crazy. Trust me you don't want those unless you are road racing, and even then, poly is a good choice.
Old 02-20-2007, 04:07 PM
C Murda's Avatar
haha i too am a driveway mechanic 100%...have converted my 91 Z from aut to T56 in bout 3 days...mainly cause it was about 100* at the time so i was sweatin ***** and bitchin...have changed 3 clutches, done 2 spring swaps about to go a 3rd with a set of adjustable coil overs...now doing my LTs....i do it all myself that way i know im not paying someone who might half *** something. if something goes wrong its all my fault and i cant blame anyone but myself. anyways, ya i just rush ordered a set of solid mounts from spohn so i can get those in while doing my header install.
Old 02-20-2007, 04:09 PM
C Murda's Avatar
oh yea thanks for the phonebook idea i tried a block of wood and it started backing out at i lifted the car so F that not tacking any chances ill just go grab the phone book..
Old 02-20-2007, 07:20 PM
well hells bells.....
Old 02-20-2007, 09:48 PM
C Murda's Avatar
how can i do this if my tranny isnt in yet? im still waiting for my built t56 to come in so as my car stands its trannyless. now if i were to lift the motor and unbolt the mounts it would probably be un balanced therfore possibly falling in one direction right? would it be possible to do one sie at a time with solid mounts? prob not seeing as they dont flex like normal mounts right?
Old 02-22-2007, 01:53 AM
TWISTEDTA's Avatar
Default Another Drive way mechanic hear!
This thread is hilarious
Now i need to go try a phone book
Old 02-22-2007, 07:38 AM
C Murda's Avatar
haha ya it worked great for me...i installed spohn solids yesterday thanks to that damn phone book
Old 02-22-2007, 10:32 AM
paper does come from wood and the phone company does send out a lot of phonebooks to ppl, now i know what you do the next time i can't find a wooden block and not scratch my pretty yellow suspension!
Old 02-22-2007, 10:34 AM
put jacks stand on front/rear of the motor and BE CAREFUL!!!
Quick Reply: solid motor mounts?
