Header bolts
Header bolts
After installing a pair of pacesetter headers I have developed a leaky header isssue (only on the drivers side).I can tighten them up but after a 30 to 60 min run they start to tick agian.I know about stage 8 bolts but want to know how much of a pain in the rear they are to install and remove.Also I have worked in a manufacturing plant that required locking fasteners(aircraft grade) which used a two sided washers with serations running the oppisite direction from each other.These things are cheap and can be had online for about 2-8 $ per 50 even for stainless(nor-lock).Anyone use these?I have the factory bolts installed with new gm gaskets. Why spend $50 if you dont have to!In the mean time Ill pick up some nor-locks and give them a try.
