Ground clearance on single chambers and catted TD's UNDER axle!
Old 03-04-2007, 02:18 PM
Out1aw's Avatar
Default Ground clearance on single chambers and catted TD's UNDER axle!
I am looking into a setup with Pacesetter LT's, Magnaflow cats, and a under-axle (budget reasons) true dual setup using Single Chamber's, and all 3" the whole way. The car is, and will stay, at stock ride height, just looking to see what kind of ground clearance I'll be sacrificing by running those mufflers AND an under-axle TD system.
Old 03-04-2007, 02:36 PM
Vesper TA's Avatar
I run that combo without cats and still have good clearance at stock ride hight. I do however scrape occasionally on speed bumps and dips in the road when I have people in my car, but not too bad. Just be more aware that you have a low hanging exhaust and you'll be fine.
Old 03-04-2007, 02:40 PM
Vesper TA's Avatar
Here is a pic of my exhaust.
Old 03-04-2007, 07:40 PM
BerryWS6's Avatar
here is mine, I have stock ride height inthe back and 1/2" lower in the front (QA1's all around). Ground clearance is great!!. I did 2 1/2" pipe after the mufflers so they wound fit my tips I already have
Old 03-05-2007, 04:32 AM
staringback05's Avatar
in other words you shouldnt have anything to worry about, ive checked into it also, ill be doing about the same setup
Old 03-05-2007, 02:09 PM
Out1aw's Avatar
And where is everyone buying their exhaust flanges from for after the muffler?
Old 03-05-2007, 04:15 PM
That's what she said...
TheBlurLS1's Avatar
Got all my flanges from Summit. If you keep the weld close to the pipe, or grind a notch in it, you can use 3/8" bolts. You just have to make sure the head of the bolt and the nut can sit flush on the flange surface and no weld bulges out in the way.
