90mm t-body tubes??
Old 03-04-2007, 05:57 PM
03 BUSA's Avatar
Default 90mm t-body tubes??
Hey guys I have a NW 90 t-body with the factory MAF. The rubber hose does not fit around the tb. What are you guys doing for this. I saw Thunder has a high flow bellow but not sure if that is what I need. Thanks for the help.
Old 03-04-2007, 05:59 PM
That's what she said...
TheBlurLS1's Avatar
It will fit if you push hard enough.
After you get it on, fits like it's made for a 90mm TB.
Old 03-04-2007, 06:11 PM
03 BUSA's Avatar
Thanks man. That helps. I tried a little earlier to do that but did not think it would work. I will lightly lube it tomorrow and give it another try. Thanks again.
