F.A.S.T. 90mm Gains on my setup?
Old 03-05-2007, 08:01 AM
nahasapeemapetalon's Avatar
Default F.A.S.T. 90mm Gains on my setup?
What kind of gains would I see from going to a FAST 90mm intake and TB? I have stock tb and ls6 intake and no MAF. I would think a good 25hp....
Old 03-05-2007, 08:23 AM
2000WS6TA's Avatar
id say more like 15. but who knows it might do better then i think.
Old 03-05-2007, 09:00 AM
teke184's Avatar
agreed...probably about 15hp...
for the $1200...you may as well upgrade the heads...get 2x that power
Old 03-05-2007, 09:15 AM
Yea i wont spend that kind of money for only 15hp, if it was 25-25+ i might consider
Old 03-05-2007, 10:21 AM
00BlueTA's Avatar
My friend with the similar setup and he pick up about 10-15 across the board but at about 5000-6500rpm he pick up 26hp. You might be able to see the same numbers, but I dont think its worth the money. But If you have the money and you want the setup, go for it!
Old 03-05-2007, 12:23 PM
linegtdt52's Avatar
I think 10-12 due to what I got
Old 03-05-2007, 12:32 PM
NoGamesLS1's Avatar
~15 on a stock motor, but with a cam and boltons you should see 25+
Old 03-05-2007, 02:16 PM
At the wheels or flywheel? I assume you were looking at a dyno. I do spin mine up to about 6700. Its a lot of money, true. 1000+ bucks for an avg of 10-15 hp seems too much, what about ported 90/90 setup, or doesnt that help much, I have seen a few threads on porting that intake...was it to match the head ports? or as well gut out the intake runners?
Thanks for your input!
Old 03-05-2007, 09:17 PM
one2run's Avatar
Over all i was pleased with mine. I did not see the gains i wanted at peak hp, but the way it pulls from 5000 to 6800! I got 20rwhp on top. the tq picked up the same 20 from 5000 to 6800 RPM's.
Peak gain you will be upset, but the perfomance on top is awesome and i lost nothing in the lower RPM's. nothing but gains and my 90/90 is out of the box.
Old 03-05-2007, 09:44 PM
00BlueTA's Avatar
At the wheels! I am not sure about porting it thow, I know my friends was bolted on out of the box
Old 03-06-2007, 10:53 AM
ohsofast's Avatar
I wouldn't get it, looking at your times I would by some sticky tires.
Old 03-06-2007, 11:02 AM
Haha nice comment on my time. I am currently purchasing a Ford 9" and will be putting some wrinkle wall slicks on it.
