EVERYONE needs to get one of these!!!
Check this out! This thing is bad to the bone. And a bargain too.
LOl @ 22000 RPM blower, that isnt **** for a turbo.
INTRODUCEING A NEWISH MOST POWERFUL ELECTRIC TRUBO…
GAIN AN ADDITION OF 60-70HP….
UNIVERSAL BOLT-ON TO ANY CARS.....
THIS IS ONE OF THE NEWISH AND MOST POWERFUL ELECTRIC TURBO KIT WITH FASTEST 22,000-RPM BLOWER. YES, THAT'S RIGHT!!! 22,000-RPM. NO BLOWER OUT THERE CAN'T BEAT THAT!!!
THIS IS ONE OF THE BEST THAT ANYONE HAS EVER PUT TOGETHER.
THIS ELECTRIC TURBO WILL PUSH 6-7PSI OF AIR AT 22,000 RPM TO YOUR ENGINE. THAT’S AN ADDITION 60-70 PEAR HORSE POWER!!! THIS IS AS MUCH POWER AS STOCK TURBO CARS!!!
NOT JUST 2 OR 3,000 LITTLE RPM LIKE OTHER EXHAUST FAN TURBO AND ONLY PUT OUT 1 OR 2PSI OF AIR.
I HAVE BEEN USEING THIS ELECTRIC TURBO KIT IN MY CAR FOR A LONG TIME AND I NOW JUST WANT TO SHARE THE POWER WITH EVERYONE.
I HAD TRY OUT ALL OF THOSE EXHAUST FAN TURBO THAT IS OUT THERE, AND THEY DON’T WORK AS GOOD AS IT SHOULD. IT WILL ONLY BOOST THE 1ST GEAR AND DEAD ON THE 2ND AND TOTLALITY DEAD ON 3RD GEAR.
THIS KIT WILL POWER THE ENTIRE RPM AND PUSH ALL THE GEAR DOWN, ON THAT ¼ MILE TRACK EVEN ON HIGH WAY WITH JUST A FILICK OF A SWITCH.
THOSE OF YOU WITH STOCK HIGH COMPERSSION LIKE HONDA WITH VTECH ENGINE CAN’T GO PASS 8PSI OF AIR ANYWAYS. THIS KIT WILL JUST BE ENOUGH WITH OUT BLOWING YOUR MOTOR.
FOR THIS KIT THERE IS NO NEED FOR CUTTING, WELDING, MESSY OIL LINE, AN ADDITIONS OF 50-60LBS WEIGHT, OR OVER HEATING AND HAVE TO UP GRADE RADATOR. NOW YOU CAN GET THE SAME HORSE POWER, WITH OUT SPENDING A LOT OF TIME CUTTING UP YOUR CAR.
IF YOU KNOW HOW TO WIRE CAR AUDIO OR AMPLIFIER THEN YOU SHOULD HAVE NO PROBLEM.
THIS KIT IS EASY TO INSTALL AND COMES WITH A VERY EASY DIAGRAM TO FOLLOW.
IT ONLY TAKES ABOUT 3-4 HOURS OR LESS TO INSTALL DEPENDS ON YOUR SKILLS.
HERE IS WHATS ALL INCLUDE:
THIS KIT COMES WITH 1 YEAR WARRANTY
5.7” INCH. ELECTRIC BLOWER AT 22,OOO RPM
POWER SUPPLY
GROUND SWITCH
BLOWER SWITCH
9GA, 16’FT POWER CABLE
8GA, 8’FT GROUND CABLE
12” BATTERY GROUND CABLE
12” POWER SUPPLY CABLE
12’FT EXTENDED CORD
3” TWIN INTAKE (IS FOR WHEN BLOWER IS OFF SO, YOU WONT LOSS ANY HORSE POWER)
TWO BLUE AIR FILTER
TWO ADAPTER 3” TO 2”INCH
IT’S BEST TO RELOCATE THE BATTERY WHEN USING TWIN INTAKE PIPES FOR SPACE, LIKE THE PICTURE YOU SEE HERE. BUT, IF NOT USING THE PIPES YOU DON’T HAVE TO RELOCATE BATTERY.
IT WILL WORK WITH ANY CARS OR TURCKS AND YOU CAN HIDE THIS BLOWER ANYWHERE YOU LIKE AND NOBODY WILL NOT KNOW.
THE BEST PLACE TO HIDE WITHOUT ANYBODY SEEING IS INSIDE THE FENDER.
POWER SUPPLY
GROUND SWITCH
BLOWER SWITCH
12’FT EXTENDED CORD
TWO BLUE AIR FILTER
Originally Posted by Blk97WS6
I have like 6 of them...they work great! Man when i hit 22,000rpm and all the "boost" kicks in....DAMN! Ill just start spinning at like 50mph.
What a ****** joke
What a ****** joke
50????? i cant even catch traction when i punch it from 90mph and i only have 2 of those bitches.....I would just like to say thank you to allt he lil people who put in 14 hour days to bring me 22k rpms of pure driving pleasure....thanks to alll the ...ahh who am i kidding i cant afford that ****** thing
POWER SUPPLY
GROUND SWITCH
BLOWER SWITCH
12’FT EXTENDED CORD
TWO BLUE AIR FILTER
POWER SUPPLY
GROUND SWITCH
BLOWER SWITCH
12’FT EXTENDED CORD
TWO BLUE AIR FILTER
I like how the blower intake and exhaust ports are only about 1" diameter. I really like how the 3" intake is necked down to 1" to feed the blower - goona get me lots of air from that! The reason the blower can turn at 22k RPM is that it is operating in a vacuum caused by the tiny inlet.
I wonder how many he has sold?
Steve
Steve
Originally Posted by craz1469
if it did make 8 psi..............wouldnt you just lose all of it throught the other filter.........whoever selling this should be shot
Originally Posted by 2001 SS Cobra Killer
I just can't believe how much this dude thinks he can sell this thing for.
Un freakin believable
