Tb Coolant Bypass Mod
if you get the right parts or the tbbypass kits that are sold you should have no problem your tb will run cooler and give you just a few ponies like around 5ish when the car is warm might as well do it... cooler intake charge=more hp. (gm did this for emissions and to warm the tb in the winter to prevent freezing) for the ls1 youll need either a small piece of 5/16 fuel line or since it was late and i didnt have the option since it was late when i did this i used a 4 inch length of 5/8 fuel hose off my motorcycle and 2 3/8" couplers. if you do not have an aftermarket smooth bellow you can get away with just a 3/8 coupler and a zip tie. but it doesnt look as clean as if you get a line or piece of hose to route it around the pulley right under the tb. hope this helps, theres many threads on this if you do a search.
That's what she said...
You can just run 1 long piece of 5/16th fuel line from the vent tube to the radiator. You may have to ream out the inside of the hose to get it to slip over the radiator side, but if you get bigger than that, it won't attach to the coolant tube.
You can also twist/pull the old coolant pipes out of the throttle body. They are pressed in MEGA hard, but they will come out once you get them on the run.
Originally Posted by SLP4CamaroSS
curious hows the blade going to freeze up isnt ther motor oil on it from the pcv???
Originally Posted by Red99TA
You don't have to put caps on the TB. As for driveability I've done this on both LS1's I've owned and even when I lived in KS I had no issues down to sub-zero temperatures at times in the winter.
Originally Posted by fortmyerspolice
It wont cause some kind of vacuum leak?
I just got done with it. Trying to fit a 5/16 hose over the radiator side is a bitch. I left the throttle body ports open for now till i find some caps. Thats fine right. It also seems theres not alot of pressure going through the hose.
I installed a Bauer ported/polished TB yesterday and decided to do the TB by-pass too. I used a solid length of 5/16" hose and a couple band clamps. The hose routed very nicely along the top of the radiator and I zip tied it to the AC line about 5" from where the hose attaches to the radiator fitting. You need to really tighten down the end that attaches to that little metal tube leading to the block. The 5/16" hose is just a little too big for that fitting. When I started my car up, I had a small leak (and I thought it was tightened down enough). I pulled out my screwdriver and tightened that clamp down till it screamed! I drove the car around a little bit yesterday and today. No leaks anymore.
If I were to do this again, I'd definitely go with the solid length of hose vice using a coupler. Why? Because a coupler is going to introduce 2 more spots where leaks could occur and it's going to ride very, very close to a pulley. A solid hose will still only have two connecting points and can be routed easily so it's no where near the pulley.
BTW, the Bauer TB is awesome! Throttle response is much more sensitive and the power comes in much more smoothly. It also whistles, which gives it kind of an unusual, if not mean sound. I like it.
Marc
Marc
Kleeborp the Moderator™
That is just a myth. Think about it this way: What temp is the tb when you go out in the morning to start your car? Is the coolant warming it? Nope.
This debate reminds me of my 73 Datsun 240. It had coolant running through the carbs. I took it to a mechanic who used to work on a racing team. It was the first mod he did; remove the coolant lines. Did not affect cold weather running, and improved performance because the carbs did not get as hot. Duh.
The TB coolant on the LS1 has minimal effect compared to the LT1 TB. It barely even contacts the actual TB itself. I doubt it's worth doing for any power increase but it can help clean up the engine. I haven't had any problems in the last 6 weeks with the temps going down into the single digits and barely the 20's during the day. LT1 TB bypass might get you 5-6 hp but the LS1 would be lucky to see 1 hp.
