Ls6 intake............
Old 03-14-2007, 09:29 PM
JDPZ28's Avatar
Default Ls6 intake............
is painted and ready to go on!
Still a little dusty from it sitting at work for a couple days.
Should I replace the gaskets that are in the manifold where it seats around the intake ports on the heads? It's a used intake.
Old 03-14-2007, 09:32 PM
SSU's Drunk Typing Whore
Lithium's Avatar
I would not replace them if they look alright...I do believe the gaskets are pretty expensive as well (why I left mine alone with the swap)
Looks REALLY good as well.
5_02ls1's Avatar
are they soft? if so no
are they hard? if so yes
if you have the 30 bucks, do it just in case
Old 03-14-2007, 10:40 PM
SweeTbone's Avatar
Good looking intake. As stated, if the gaskets are in good condition, re-use them. Take them CAREFULLY out of your old intake. There is a small "dot" in the corner on the gasket. You can use a micro screwdriver or a scratch awl to start to get the gasket out. If you LS6 has them on it, I would just use the ones that will be coming off your current intake.
