broken oil pressure sending unit
hey guys i broke the oil pressure sending unit while installing my ls6 intake.my question is, is there anyway to put a new one on without taking the intake off? and is it ok to drive the car while the sensor is broken? thanks everybody
Restricted User
the leak would not be the problem. not knowing you had lost some/all oil pressure for what ever reason and driving that way would be the thing. better safe than sorry when it come to replacing motor.
I broke mine in half and it acted like a plug for the oil. If it was me I would not drive the car unless it was to get a new oil sensor and even then i would look for a ride. As stated before you need J-41712 tool to install the new sensor and it is worth the hour to remove the intake when reinstalling the oil sensor.
Same thing just happened to me when installing BBK intake. I removed the intake just to make sure everything was good. I have a 2000 z28 and found that the replacement sending unit (purchased from GM) was made of thicker plastic, the stock felt pretty cheap. If you havent already purchased a replacement, one member said that O'Reilly's sells them for bout $21 (GM charged me $58). And like everyone said, I would not risk driving on it until you get the unit installed, simply not worth the risk imo.
As far as your other question, I don't see how there is anyway to reach the sending unit with the intake on, but I've been proven wrong before on these cars.
Originally Posted by senicalj4579
i'm just about to do an ls6 intake swap. i'v looked all in my gm service manual and it shows a small pic of it with no info. where the hell is this damn thing!?!? is it attached to the back of the intake or something?
I broke mine too last Saturday! @#$@! I ordered a replacement from Advanced AP for under 40 bucks and got out early from the hospital and swapped it out today in less than 1 hour. I removed the intake just enough to get to the sending unit and replaced it. This time I just disconnected the booster hose from the back of the intake and just put it back on after the intake was on. It is on there pretty snug so I doubt that it is coming off even with the clamp removed.
thanks for the info everybody. now i just gotta get time to put it in then its going for a full dyno tune ill let everybody know the results thanks again.
******* HATE that thing. Why did gm design it to be directly behind the intake manifold. Broke mine clean off swapping in an LS6 intake on my old firehawk. Had to overnight the part from SDPC. The shipping was more then the part itself.
