85mm PP throttle body
Does any body have the PP (professional Products) throttle body I have the 85mm. After I installed it on my car the throttle plates only open about 85% when useing the gas pedal.
Just wondering if anyone has the same t/b and problem
I have the same TB, not yet installed though. It came with two throttle cams. Did you install the correct one for your car? If you have a 98-99 it uses the smaller cam. 00-02 use the larger cam. You CAN interchange the cams, but you have to replace your thottle cable to do it. If you have a newer model car and use the smaller cam without changing the cabe, you're not going to get full throttle.
Damn, I totally may have figured out your issue. On the side of the intake where your throttle cam is, see if the cam hits the PCV tube coming out of the intake. My friend had the same problem on his '00 Formula and he had to cut a notch off the top of the cam so it would hit full throttle.
Also, did you use the spacer plate that came with the TB? If not, that might account for the difference.
If you buy the Typhoon 85mm intake - no need for the adapter with their 85mm TB.
