Quick longtube install question
Old 03-17-2007, 06:23 PM
JL8Jeff's Avatar
Default Quick longtube install question
Does that driver's side casting nub need to be cut off or trimmed back for all longtube header installs or is it just a Pacesetter issue getting the header in? Once the header is in, does that nub still get in the way or is it just an install issue?
Old 03-17-2007, 07:15 PM
bww3588's Avatar
ttt...........
Old 03-17-2007, 07:21 PM
ArrestMeRed99Z28's Avatar
I didn't need to cut anything, block, k-member, nothing, they slid right in.
AJ
Old 03-17-2007, 07:44 PM
lastcall190's Avatar
I had to cut it completely off. As you can see from our responses, there's no "rule", it's luck of the draw far as I can tell.
-J
Old 03-17-2007, 07:56 PM
matt94z's Avatar
I have Hookers, but I didn't have to cut the tab. Just depends on your car I guess.
Old 03-17-2007, 08:03 PM
2_wacko's Avatar
AJ
Same here.
Old 03-17-2007, 08:20 PM
Hard Core Z28's Avatar
You need to get the car higher in the air.
Old 03-17-2007, 08:45 PM
bww3588's Avatar
im doing motor mounts, and i have a lift so when i get the motor mounts off, ill raise it up just a tad and slide the headers "in", bolt the motor mounts back up and repeat on the other side.
Old 03-17-2007, 08:47 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
If you have worn out mounts that might cause a clearance issue.
Old 03-17-2007, 08:50 PM
bww3588's Avatar
what replacing the motor mounts the same time i put headers in?
