Shift Light Wires
Old 03-17-2007, 08:30 PM
98z28girl's Avatar
Default Shift Light Wires
I recently purchased a raptor shift light for my 2000 SS and i need to know if anyone knows which wire color hooks up to the VCM and where.
Thanks!
Old 03-18-2007, 10:28 AM
ShevrolayZ28's Avatar
Thanks!
Instructions:
http://www.raptorperformance.com/Che...tall_guide.htm
Old 03-18-2007, 12:05 PM
SweeTbone's Avatar
More instructions from my small write up.
https://ls1tech.com/forums/showpost....33&postcount=7
Old 03-18-2007, 12:27 PM
98z28girl's Avatar
Thanks guys! That makes it a lot easier to understand.
Old 03-18-2007, 12:48 PM
Make sure you get a good seal and that the gasket is properly positioned when you plug the PCM back in. Things can go to crap if water gets in there. And be careful not to overtighten the bolt that holds the plug on. Good luck!
Old 03-19-2007, 10:55 AM
98z28girl's Avatar
I ended up using the ASR wires to connect the shift light. Everything worked out great. At first it wouldnt turn over then i realized i needed to tighten the top of the PCM. (ha ha!)
Thanks for all the help!
