??? about grinding ls6 intake ribs down
Old 03-22-2007, 07:15 PM
senicalj4579's Avatar
Default ??? about grinding ls6 intake ribs down
what are these ribs for underneath the intake. would i be able to just grind all of them down before i install or do i need these for some reason?
Old 03-22-2007, 09:14 PM
tbick's Avatar
i grinded all the ribs down and had no problems, make sure you get the ones underneath the foam as well. I dont know what their purpose it but so far everything is fine.
Old 03-22-2007, 09:21 PM
well this might sound stupid but, what foam?
Old 03-22-2007, 09:25 PM
Z28LS1camaroguy's Avatar
there is foam on the bottom of the stocker you can use, my SLP intake didnt come with any new foam either. But i didnt have to grind the ribs off of mine and it fit perfect no leaks and sealed flush no problem, maybe SLP fixed that little problem.
Old 03-23-2007, 12:15 AM
anyone know what hell the ribs are for. i just wanna grind everything down now so when i take the old intake off i dont have to **** around. tbick, when you say you grinded all the ribs down you mean every single one right? how did everything fit under there? do i have to reuse the foam?
Old 03-23-2007, 12:19 AM
Grimes's Avatar
ribs are there to add strength to the intake, I would just grind down the areas you need to clear the coolant tubes, not everywhere!
Old 03-23-2007, 09:27 AM
wow thats pretty cool. saved yourself some work on that one. i almost picked up the slp version. maybee i should have. do you know what the foams purpose is?
if those little 3/16 ribs are really there to add strength to the intake i'll be grinding all of them down tonight while laughing my *** off. they are coming off tonight
Old 03-23-2007, 09:38 AM
The foams purpose it looks to me is to keep water out of that area and from the knock sensors, and it looks to me that the ribs on the slp version are really small and fit perfect. hell i didnt even have to bend the coolant lines at all, i was really shocked and impressed with how much better my car responds and drives now.
Old 03-23-2007, 09:41 AM
brad8266's Avatar
You can grind them down, I did it to my old LS6 intake and ran it for a while and it was all good. Just grind the spots that you need to.
Old 03-23-2007, 09:51 AM
hey thanks for the replys guys
Old 03-23-2007, 01:20 PM
tbick's Avatar
senicalj4579, I grinded every rib down and then used some weatherstripping foam where the old foam was. It fit perfectly and I have no leaks or problems at all. For me it was easier to remove them all than to keep tring to guess which ones needed removed.
Old 03-23-2007, 02:10 PM
Speedmonster185's Avatar
I ground mine down too, but only the ones I needed to. I didn't have to guess though, the old intake's foam had a perfect little design in it where the pipes were .
So far so good, nothing bad has happened.
Old 03-24-2007, 08:30 PM
yeah man, the thing is i got the old maifold still on my car and the ls6 on my workbench. its just to much of a pain to have to **** around with the new intake so i'm just gonna cut all the ribs down and then take off the old one and slide the new into place no question and no guessing.
about the foam.......i didnt have any clue there was any underthere in the first place. do you think the ribs are there to help hold this foam in there or something? (just guesing) anyway.... why didnt you use the old foam?
Old 03-24-2007, 08:32 PM
well thats something to think about. maybee i should take the old off first and take a look at that foam,it could be a nice little template
Old 03-24-2007, 09:47 PM
Thats what i did. I don't see how there would be any way to really even guess where the lines go very well in there. It worked pretty well. I just tried guessing from the foam and then I would go over and set it in place and feel if anything felt like it was still touching. I did still have to push the lines down a very small amount (1/8" at most maybe). Worked pretty well in my opinion, and I'm not worried about it at all.
Old 03-24-2007, 10:11 PM
Tainted's Avatar
I know someone will ask for these eventually so im gonna go ahead and post'em up!
Old 03-24-2007, 10:18 PM
another + 1 for tainted lol. so tainted, can you tell us what these stupid ribs are for?
Old 03-24-2007, 10:20 PM
Tainted's Avatar
for "strength"
they wont offer enough strength to matter so jsut whack'em all off
Old 03-24-2007, 10:30 PM
exactly what i was thinking bro. how thefuck is some 3/16 ribs gonna help stregthen a pretty solid piece of nylon or what ever the hell it is. the god damn things are coming off!! all of them lol
Old 03-24-2007, 11:52 PM
ryle's Avatar
Thanx for the Info guys, I am also about to install my LS6 Intake and this helps a lot
Quick Reply: ??? about grinding ls6 intake ribs down
