Jet Hot y-pipe Leak Solutions
Hello,
I have a Jet Hot Y-pipe. And it bothers me. It consistantly leaks. Has anyone with this setup found any solutions? It appears the problem is that either the length of the cat is too short since it slips either too far forward or too far backward and creates a gap between the two butted pipes in which the cats sit. Or, The band clamp is not large enough so that it wraps completely around the cat/pipes, creating a seal when completely wrenched down.
Any inputs greatly appreciated. Thanks.
Rick M.
Rick M.
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Originally Posted by Jeremiah
I rolled up aluminum foil and wraped it around the joints and tightened the clamp over it and it sealed good.
Originally Posted by NHRAMAN
That is what I have been advising on this board alot lately.
a local shop in raleigh charged me 60 bucks to do that and weld in my SFC's
I like to cut some short slots on opposite sides of each inlet and outlet so when you clamp it the ends can close in a little tighter. This also makes it easier to separate exhaust if you need to.
