well i got my cut out , and
Old 03-23-2007, 10:16 PM
zrater's Avatar
Default well i got my cut out , and
weres is the best place in the exhaust to have this thing welded up, and what way
do you point the cut out dump pipe, left or right or down towards the ground the exhaust is totally stock but
muff has been changed. and were do you run the wires to and what power source do you hook this to ... thanks
Old 03-23-2007, 11:30 PM
aaron653's Avatar
right under the rear passenger seat is where most people put it...I put mine farther back just as the pipe starts angling up toward the rear axle..you can run the wire through the drain plug that is right underneath the rear passenger floorboard...I cut a small hole in the rubber stopper and ran the wire through it and then put the stopper back in...and I wired mine to the cigarrette lighter
Old 03-24-2007, 01:19 PM
zrater's Avatar
thanks very much,
Old 03-24-2007, 02:21 PM
gyrene2003's Avatar
so what brand did u g with?
