O2 sensors not fitting into Pacesetter Lt's??
I just installed a brand new set of Pacesetter Long tubes(race) and i could not be happier with the ease of install.
They went in with NO troubles at all!
Now.... I went to hook everything back up and found that the factory oxygen sensors do NOT fit into the headers due to clearence issues with my A4 trans.
I managed to get the drivers side o2 in,but the wires actually rub against my shifter linkage.
I can NOT get the passenger oxygen sensor even into the header due to clearence issues with the trans,the sensor hits the trans.
Any ideas?????
headers look great and installed beautifully,i have seen issues with oil filter clearence(did search) but nothing i found so far about o2 sensors.
Got any ideas?? I bought then from Speed Inc . I have not talked to anyone yet,i just left the garage. I JUST put down my wrenches!
TIA
Dave
Any ideas?????
TIA
Dave
wow I never heard of that problem!! I know my pacesetter longtubes had the air and egr fitting on the wrong tubes in the wrong spot I was able to get air on but had to
!egr (which I didn't want to do) maybe I'd try to compare with another set to make sure the o2 holes are in the same spot!.
i just installed pacesetter longtube race style headers 2 days ago in my 00 a4 and i had no cleance issues at all i know it was a tight fit to get the passanger one in but i did it and it took a while just be patiant my friend u will get it in!
Thanks,i will try again tomorrow after i settle down and clear my head.
My Hooker headers were MUCH harder (tighter) to installed and remove. I bought the black Hooker Lt's and they rusted,so i replaced them with the Pacesetters with the Armor coating.
Thanks
Dave
Originally Posted by amsterdamn
'99 Z28 A4 here with Pacesetter LT's & ORY, also bought from Speed Inc., and Bosch 13111 O2's. No issues.
But i don't have the equipment for it.
Thanks
Dave
Originally Posted by redsscamaroboy
If all else fail's i will try the Bosch sensors...
I re-used the stock O2s on my pacesetters. I noticed mine contacted the shifter linkage on the DS, but it looked like they only hit when the trans was in park. Check yours out...
As for the PS, I had no issues there.
Sorry i have been working way too many hours.
I called Speed Inc and was told by a sales man that when they install the Pacesetter LT's on an Automatc LS1 they do not use the provided bung for the passenger O2. they plug it and weld in a new one in a different spot for clearence .The M6 is no trouble.
My first question was ,why did no one tell me when i ordered them?
I was recommended to Bend the header!
Or to plug the bung and drill a hole then weld a new bung in a better location!
Neither option sounds cool to me, i called Pacesetter.
I talked to Joe in sales and he asked for pictures,so i borrowed a camera and snapped a few shots under my car and e-mailed them to him.
I waited a few days and finally I called back.
I was told the picts were forwarded to another department and he would be contacting me with what they come up with.
So no word yet.
I have returned the camera or i would post some shots right now.
Maybe i can get the camera again this weekend and show you what i am having issues with.
thanks
Dave
So no word yet.
thanks
Dave
So no word yet.
thanks
Dave
So no word yet.
thanks
Dave
I've always wondered why they put the sensors sticking in. Besides the fit problems people are having, you have to route the wires up around the headers rather than right down the subframe. How tough would it be for them to just put the bungs on the outside? And why don't they (and the vendors) let you know about the needed A4 mod - it's not like 99% of the cars out there are manuals? Also, it's not like you want them to just barely fit - they need some space so the don't get damaged when the motor moves around under torque. Rant off.
I wanted a bit extra clearance on my FlowTech's so I stuck a big bar in there and pried the driver's side down about 1/2''. If you have a long, strong bar (no jokes please) it just takes a bit of muscle. It's what I'd do rather than remove them or hack them up moving the bung (especially if they are coated).
Steve
Steve
Ok i now have the photos i sent to Pacesetter in this computer,how ever i am not a smart enough man to figure out how to show all you wonderful people just yet. .
I will try and figure it out after i get some rest(just got home from work)
Joe @ Pacesetter and i talked today,he is going to take a header out of inventory and put the sensor bung in a spot that will work for me. Then re-appliy the coating so no rusting around the weld.
Should be handled inside of a few more days(4-5).
Very helpful company,I am looking forward to fixing this issue and when the GTO (2006 LS2) headers are available , getting a set of those as well.
06 Goat(our latest toy)
Dave
Dave
