Pacesetter LTs & TSP Ory installed
Old 03-26-2007, 09:34 AM
ddcook07's Avatar
Default Pacesetter LTs & TSP Ory installed
All installed this past weekend. Now the exhaust pops and it seems hesitant. The car feels jumpy. Any suggestions?
Old 03-26-2007, 09:41 AM
3800RS's Avatar
check your plugs and wires
Old 03-26-2007, 09:45 AM
ddcook07's Avatar
Should I get new plugs and wires? I mistakenly cut a little of the rubber housing from one of the wires, but used electrical tape to seal it.
Also, which plugs and wires to go with? I currently have autolite double platinum on there now.
Old 03-26-2007, 10:11 AM
steveo346's Avatar
Taylor 10.4 Wires And Some Ngk Tr55 Plugs From Your Local O'reiley Auto Parts
Old 03-26-2007, 10:14 AM
BIG_MIKE2005's Avatar
Yea, I would get new wires & you could just get another new set of the Autolite plugs. Our local tuner Ed Wright suggests to everyone that asks about NGK, to switch to Autolite. I'm gonna swap plugs when my nitrous kit goes in even though I'm currently running the TR6's.
Also did you use O2 extensions or make your own with the crappy little kit??
Old 03-26-2007, 10:18 AM
ddcook07's Avatar
Yeaup crappy little kit. Should I buy premade extensions?
Old 03-26-2007, 10:19 AM
ddcook07's Avatar
Also, the rear O2s shouldn't have any affect on perfomance, right or could that be a part of the problem also.
Old 03-26-2007, 10:25 AM
I bought the extension from TSP when I ordered my LT's. Just plugged them in & put the O2's in the LT's. Haven't had a issue yet & yes, your rear O2 get deleted & your fronts go in the LT's, but to reach you either have to make a extension or buy one.
Old 03-26-2007, 10:35 AM
cookba's Avatar
couldnt resetting the pcm help as well if none of the above mentioned items work?
Old 03-26-2007, 10:42 AM
resetting the PCM isn't gonna make any codes go away since there are now rear O2's missing & its also not gonna fix the problem if there is a loose connection in the homemade extension or if its the plug wire he accidently cut.
Old 03-26-2007, 12:36 PM
ddcook07's Avatar
Any more suggestions?.........ANYBODY.....
