Installed ls6 intake 2 days ago
well i installed my intake 2 days ago and didnt break the oil sending bitch in the back. it was my first time so it was a pain in the *** install. but you know what they say....."practice makes perfect right" lol. well i got my practice in because i ended up snapping 2 intake bolts and i had to take the new intake off yesterday The second time is the easy part because i knew exactly what i was doing. i ended up having to drill out the 2 bolts with a small bit and then back them out with an extractor. so,got them out, got the intake back on and now i'm waiting to get some new bolts to sock it down. i managed to be able to start the car when i had it bolted down 2 days ago and it sounds lopie.
some of you guys already know what a nightmare install this was for me because of getting the coolant into my ports. man,this was the ls6 intake install from ******* hell let me tell you
Originally Posted by Luna
lol that really sucks. Those bolts don't need much at all, I think its like 37 ft/lbs
yeah its 44in lbs first then 89in lbs second. i just picked up a good craftsman torque wrench today. the one i was using was junk. yeah, you dont need to tighten them to much. its hard to tell because you wanna make sure the gaskets are sealed up nice and its not still being held up by the coolant lines underneath. its all good. i should have my bolts tomoro and i'll sock down the intake.
as far as good advice for installing the ls6 and not breaking the sending unit goes.....lift up the intake,try to pivot the back to the right side of the car while you pull it out,and while your doing that keep feeding the break booster hose little by little around the sending unit in the back. thats the best advice right there
Originally Posted by senicalj4579
lol well it never ends. when i put the bolts back in today i have to take the damn intake partialy out again because i forgot that you cant fit the bolts in the damn holes in the back unless its out. i got everything hooked back up. wtf
