Best Clearance Y pipe...PaceSetter?
I dont think I found a clear answer on this when I did my searching:
What Y pipe offers the best ground clearance? Bumping probably wont be an issue because I already have poly mounts and a bumpstop (thanks to the TSP catted Y).
The Pacesetter Y is one piece right? Does it have good clearance? Any coke can pics (I know there has to be one somewhere)?
I am on a budget and clearance is my main concern. One day I will get custom 2.5" true duals. But for now I need to fix this worthless LM and keep it from falling off again due to a terrible fit with the TSP Catted Y. Any help would be awesome!
All i can say is wow. How did you get that kind of clearance out of your TSP catted y? Mine is also stock height and i have maybe 3/4 of an inch more than a coke can ON ITS SIDE on my drivers side. I have maybe 1/2 an inch to go before i hit the cross member.
Are there any pics of the PaceSetter Y installed?
I dont have any side shots with the suspension loaded but I never scraped the Y pipe on anything. As you can see the droped down crossmember from the Spohn TA was not needed, even with the strait crossmember I would have had approx. 1" clearance for the I pipe.
I dont think its possible to have more clearance than with the Jet hot Y.
I cant stand those conventional exhaust clamps anymore. Why do you bother with those pinching pieces of garbage? Why not just get a SS band clamp and wrap foil around the seam, creating a leak-less system.
Well I ordered a Hooker CB (to replace the LM) and a Pacesetter Y. I will be sure to post up some pics when I get them both on. Is there much rasp associated with the pacesetter Y?
I hope this was a good decision, lol. I guess if I dont have to worry about my LM and all 19 joints and clamps coming loose any more then I will be okay.
Poly mounts and a bumpstop... I guaruntee it will still bang... just because its on MY car
