98 knock sensor question
That's what she said...
I would change 'em. I was constantly getting 4* at the track, swapped them out, and it dropped dramatically. I also went in and edited the KS tables to resemble the 2002 tables.
My friend went from 12.0 to consistant 11.7's after his were swapped from his '98 lol. You also have to get a new little harness for them, as they have different clips on the new style sensors.
Originally Posted by bad6as
so the 98 knock sensor harness gets un pluged from the main harness
the new knock sensor harness gets pluged in the the main harness and also to the sensors
Familiarize youself with how the new harness unclips from the new knock sensors. It took me 2 flathead screwdrivers and a buddy to get mine loose. You have to depress both sides and pull up at the same time, it's hard when they're down in that hole and your fat fingers won't fit.
well you could cut the wires and i guess you use a socket and just un screw them?
Originally Posted by TheBlurLS1
Yep. Those 2 wires heading toward the back of the motor swing around and there's a weathertight connector just out of view. You simply unplug the old one and clip on the new one. New knock sensors just screw in.
use a pair of needle nose pliers, and squeeze the connectors, were they are ovaled. If you look at them, they are circular, but their are two bulges on each side of the circle, that is where you want to squeeze. just apply a little pressure, and walk the connector up wards off the sensor.
Updated sensors: 12589867
Updated harness: 12601822
Hi
I assume I will need 2 sensors and 1 harness? Or does each sensor have its own harness? Thanks.
