After installing headers, do I now need a tune?
Old 04-01-2007, 07:32 PM
DANSBIRD's Avatar
Default After installing headers, do I now need a tune?
Ive been told that the MAS should do any adjusting that may be needed. But Iv also heard that Id need a tune. My understanding is that a tune is not needed unless im doing something internal like a cam.
Thoughts?
Old 04-01-2007, 07:37 PM
ls1amit's Avatar
Yea a tune will make it run better and give you about 10 wheel hp from what i have seen.
Old 04-01-2007, 07:43 PM
Tainted's Avatar
a tune will take uot any codes, and get you more power and adjust everything right off the bat. I recommend it, I did my tune when I got my headers and I know for a fact it helped me out.
Old 04-01-2007, 07:50 PM
8a8mfh's Avatar
I've spent the weekend tuning my car after headers. different things changed everything from the seat of the pants acceleration to the sound of the exhaust. So I'd say yes also.
Old 04-01-2007, 07:58 PM
black01_WS6's Avatar
you don't need a full tune- If you have a local shop that works on ls1's they most likely keept a tune for headers that they can work off of for your car. Most shops charge about 150-200 for a basic tune and up to 400-500 for a full tune.
I would reccomend a tune a tune either way- it will only help you.
Old 04-01-2007, 08:19 PM
Grimes's Avatar
To get the most out of the headers, a tune is a good idea!
Old 04-01-2007, 08:25 PM
SVThis's Avatar
it will help but is not NEEDED...if u plan bigger and better things in the near future(cam, gear or so on) id wait and pay the big bucks then and not big bucks now AND THEN
Old 04-01-2007, 08:59 PM
FireSilverLullaby's Avatar
Yeah a tuned helped out alot on my car. It also increses throttle response and the car sounds alot crisper at wot.
Old 04-01-2007, 10:39 PM
DANSBIRD's Avatar
Thanks guys
Old 04-01-2007, 11:01 PM
winterftbl's Avatar
With a headers install couldn't you just tune with a handheld instead of going to a shop to get that extra ten hp?
Old 04-02-2007, 12:47 PM
lsx24's Avatar
Get a full dyno tune. It will clean up your air/fuel ratio and improve high end hp and also throttle response. Recommended any time you drastically change airflow, like with headers, to get what your potential is.
Remember future re-tunes are usually much less, so when you get a cam you can get a retune for less than the full price.
Old 04-02-2007, 01:01 PM
Checkmate's Avatar
I would highly recommend it, made a world of difference with my old car.
Old 04-02-2007, 01:02 PM
MidwayAvenue's Avatar
so what exactly do you tune on a basic tune after headers? besides air fuel ratio and deleting any codes..is that it or can ther be more to mess with to get a better outcome..
Old 04-02-2007, 02:00 PM
lsx24's Avatar
For a full tune a few different things are done, depending on the tuner. Air/fuel ratio, timing, VE tables, fan settings, MAF adjustments for big cams, A4 tuning if A4....
Old 04-02-2007, 02:11 PM
Rob98LS1's Avatar
I'm about 30 hp down from where I should be because I didn't get a tune.
Old 04-02-2007, 02:19 PM
ibanez7's Avatar
Thoughts?
if you plan on adding heads and cam, wait til tune the car then!!!
if your just staying bolt on, then tune it now!
you car run without a tune on headers! You will just have an SES code and run alittle rich in gas!!
Old 04-02-2007, 07:47 PM
slimcracka's Avatar
well i got a dyno tune after i did my headers...b4 i had manifolds with an ory and all other boltons with a street tune. after the headers i went to get the dyno tune and half way threw the first pull he aborted the it...it was at 15:1 afr.. thats how lean just headers made my car....crazy yes but its possible...now you do have cats so that might change a couple things but i would just to be safe...
Old 04-02-2007, 08:19 PM
SSwanner's Avatar
dan, as slow as you are with mods i would say get a full dyno tune
atleast get a street tune though. whatever you do, don't waste your money on a handheld tuner.....
Old 04-04-2007, 08:02 PM
slimcracka's Avatar
owned
Old 04-04-2007, 10:11 PM
DANSBIRD's Avatar
My car is running like absolute hell right now. It kinda sputters a bit while in gear. Is this due to the lack of a tune? or something else? PS, i havent checked the plug wires, but it only happens on occasion, not all of the time
Quick Reply: After installing headers, do I now need a tune?
