What temp should 160* t-stat run at?
Old 04-02-2007, 12:19 PM
BADSZ28's Avatar
Default What temp should 160* t-stat run at?
My car runs at 180* and I just wanted to see what everyone else is running at. Seems high for a 160* stat to me. I could be wrong though. Reasonning for the post. I feel like I may have a 180* stat in and want to check what it really is since I thought I bought a 160* stat.
TIA
Old 04-02-2007, 12:57 PM
That's what she said...
TheBlurLS1's Avatar
Mine runs 180-185 with a 160* stat, most all of them do, no worries mate.
Old 04-02-2007, 01:10 PM
jmm98LS1's Avatar
Mine runs between 177* and 184* with a 160 'stat, your fan settings have as much to do with your operating temp as the thermostat does.
Old 04-02-2007, 02:14 PM
BADSZ28's Avatar
Good news is I don't have to swap it out then. Bad news is where the hell did my power go yesterday at the track? I thought it was hot and KR was kicking in but I did not log since it was cold and did not feel this before. So???
Old 04-02-2007, 02:16 PM
lsx24's Avatar
My bird ran at 180-185* consistant with a 160* stat, programmed.
Old 04-02-2007, 02:27 PM
bczee's Avatar
Even if you have a 160 T-stat.. if you engine wants to run hotter than 160.. it will continue to raise in temp until the Fans come on or you are at speed. What also must come into play is when the Fans come on.. have they been programed to come on at 180 or what ever you want to keep the engine at. A stock T-stat is most likely 195 and the fans come on around 223 deg.
You may have lost power due to your Fuel table wanting to be run at a higher temp and you should look into having your PCM and Fuel tables reprogrammed for the lower Temp that your engine is now running at and never reaching the correct temp for the Fuel Tables and peak performance.
Old 04-02-2007, 02:31 PM
ICRAZY6's Avatar
I also believe the location of the temp sensor on 00-02 cars is in a different location. Mine runs about 180 all the time, I've programmed the fans to come on at 180 and the 2nd fan to come on at 195. So that would help.
Old 04-02-2007, 02:38 PM
BADSZ28's Avatar
I should have noted that the car is tuned for the stat and fully dyno tuned.
Seams we have determined I do in fact have a 160* stat so thanks for your help.
Now I am looking for help on my power problem. The temp was in the mid 40s I would say with cool downs between runs. The car reached full operating temp as I pulled to the burnout box. I only made 3 passes thanks to the rain. 1st pass spun and trapped 117.89, next missed 3rd and trapped 117.9, 3rd pass no spin, perfect through the gears and only trapped 106??? Car felt weak and fell on it's face on launch. You can see from my previous two runs there is a 120+ in it easy on a clean pass. After I left the car felt strong again. Any speculation on what may have been wrong? No SES light and the temp looked normal on the gauge. I have hot lapped the car without problems before on much warmer days.
Old 04-02-2007, 02:54 PM
black_z's Avatar
Is your can a manual? How is the clutch?
Old 04-02-2007, 03:07 PM
SSpdDmon's Avatar
On cool days like today (it was 40*F this morning), my car sticks between 167~169*F on the highways. In traffic, it'll get up into the 180's. Like mentioned above, it'll depend on the weather and where your fans are set to come on.
Old 04-02-2007, 03:22 PM
BADSZ28's Avatar
1k miles on Spec 3. Not slipping. I have cut 1.51 60s without issues.
Fans are set right.
Old 06-10-2007, 08:17 PM
SpdFrk1990's Avatar
I really want a 160 degree stat I hate how hot it is under the hood running at 210 with headers. I have efilive and can tune it for the cooler temps. Where is the best place to get the 160? Also what temps should I set my fans to you think??
Old 06-10-2007, 08:21 PM
lsx24's Avatar
My Tuner set my fans such that all the time I was at 185*.
Old 06-10-2007, 08:45 PM
SpdFrk1990's Avatar
I lowered them 25deg ill see how that does.
Old 06-10-2007, 09:13 PM
2 fast 2000's Avatar
After hearing all this I'm starting to think something is wrong with my set up. I have a 160 stat and my temp gage is still reading 208 at all times. It's tuned for the stat also. Is everybody running a different gage than the factory one? p.s not trying to hijack, just another question since everbody is on the temp questions.
Old 06-10-2007, 09:19 PM
SpdFrk1990's Avatar
Yehh 208 thats about what mine runs on stock fan settings and stock t-stat.
Old 06-10-2007, 10:31 PM
dummer's Avatar
After '98, or maybe '99, can't remember for sure, they changed the temperature qauge on the f-body, it's not accurate at all if you are going by the gauge on the dash. It's more like an idiot light than a gauge. If you monitor you temp with a scan tool, you will get a more accurate idea of what you are running at.
Another thing, what most people don't understand about a thermostat-the temp it is rated at is where the stat just begins to open. It will not be full open until at least 7 to 10 deg. higher, and that is what the engine will run at, IF your fans are programmed for the lower temp as well.
Old 06-10-2007, 10:32 PM
hallass's Avatar
if you're watching the stock guage, then that's what it's going to read. i have an autometer water temp guage with a 160 thermo and fans tuned in an it'll read 170, 180, 175, 160, or whatever it's at, but the stock guage jumps right to almost 210 once the car runs for a few minutes and sits there. the stock guages are crap and aren't accurate at all. they're pretty much just a dummy light with a pointer i guess you could say.
Old 06-10-2007, 11:18 PM
SpdFrk1990's Avatar
With my fan temps turned down 25 degress it stayed idling at 198 degress and that was from the efilive gauge.
Old 06-11-2007, 12:37 AM
speed_demon24's Avatar
169-171, gotta love the becool radiator.
