Descreening my stock MAF
I have a 2000 vette with a varam setup and I was wondering if it would be ok to descreen my stock MAF. I have a Diablo predator as well if that would help out any. I was told it would be fine but its a 2000 not a 98 so I had to ask. Thanks.
you will get mixed answers some say you wont get any problems other say to keep it on that you are good for 500hp. i dont have it but wish i did cuz it seems to make it a bit eaisier to fine tune the engine. sometimes on auto's it will make them shift funny also. i dont know if the diablo will be able to tune for that either. i would say keep it till you get a h/c combo or more.
do whatever you want to do. Thats the straightest answer youll get. Some say you need it to straighten the airflow, some say you want the turbulance for atomization. BLah blah blah whatever reason you get (for removing/or keeping) there will be a post to debate the validation. Just like Newtons III law:
It is not always going to be one little mod that make a huge change, it is the sum of all of the parts.
If it helps, the Z06 MAf does not come with the screens form the factory, there are several MAF from the factory that do not come with screens. I dont think the screen is there for "air flow straightening", I just dont see that little screen doing that. Plus it is not like the airflow is going right into the combustion chamber right after the MAF. It has to enter the plenum then be directed by the runners into the intake port and at the intake valve.
I am sure if any airflow straightening needed to be done for velocity it would be more beneficial to do it right before the air flow enters the intake valve.
That screen is nothing more than a way to offer the tiny fragile elements of the MAF some protection for large debris hitting them and breaking them.
omg
i took mine out it done nothing then i stupidly ported it."damn internet" well it ran good for around a hundred miles or so.then the ecu noticed the change and went all to hell.luckily i found one on ebay really cheap.
the wife was goin i told you so i told you so.i even made a post that went on for days at how much porting it and the t/b helped .oh well id leave it be.gm put it there for a rewason
Well if it doesnt hurt anything I will remove it. On my 98 z28 we ported the MAF ends and it made a difference but I was told not to on 2000 and up. I also heard you can turn it backwards and it would make a difference but I havent tried that either.
leave it
Leave it on there i just had to buy a new one cause i couldnt get a good dyno tune without it there . There was 2 twin turbo vettes there at the shop on with 670 hp the other with 723 hp both with stock mafs on them
Once again there is no way that the screen that is maybe 1/2" from the MAF elements is going to straighten any airflow out. If straighten the airflow out was so critical dont you think the Z06 would of have had the same screen on it from the factory?
Some years back one of the sites did a CFM flow test and it is worth about 50cfm of airflow to remove the MAF screen. I have done it on every car I have even owned and never had a issue.
I did the ported MAF as well and had bad luck with it so I replaced it with a stock one and took the screens out. I also used poly ends but was having some tuning issues so I went back to the stock ends to resolve that. The screens are still out though.
