UD pulley on DD, with system, worth it?
Old 04-04-2007, 09:17 PM
z28pat's Avatar
Default UD pulley on DD, with system, worth it?
I'm questioning getting the UD pulley either ASP or SLP because I have 2 amps running in my car, and don't know if it'd be wise to slow the accesories down to gain a few HP. the battery meter already goes a little to the left of dead center when I turn on the AC with the radio going.
pat
Old 04-04-2007, 11:03 PM
Blacker's Avatar
I have been running 2 MTX Amps and an underdrive pulley for many years with no charging issues.
Old 04-05-2007, 08:03 AM
Kleeborp the Moderator™
MeentSS02's Avatar
If you are already seeing charging issues, I wouldn't do it...to tell you the truth, I'll probably be doing back to a stock sized (but not stock) pulley to drive my accessories (I only have a small, two amp system). I never felt anything from my UD pulley, and it has only proved to be a hassle with an aftermarket alternator (I had to idle my stock cammed car at 900 RPMs to get my 160 amp alternator to charge properly).
