Which UD pulley? ASP or SLP?
I have the ASP. No problems so far. Makes a slight differance in power. I didnt Dyno mine before and after but most people say about 8hp. Just make sure to replace the bolt when you change the pulley.
That's what she said...
You're going to get a deadlock on opinions, and there really isn't much difference, which is why it's a pretty even distribution of who has what.
After much research I decided on going with an ASP, only because I ordered my cam and everything else from the same place and that's what they sold. It works perfect and I've never had a problem with it. Took it off and reinstalled it once already with zero problems on either install.
Well if thats the case then I would be better off buying the SLP if they are identical. I wish someone would chime in and tell me what type of real world gains they have seen.
