Before or after? oil pressure sending unit
So like an idiot i break the oil pressure sending unit while swapping intakes. Right now there is no intake on it and im wondering if it would be easier to put the new oil pressure sending unit on before i put the ls6 on, or after? Also, could the car be driven w/o a sending unit?
thanks
thanks
Before as it is almost impossible to install with the intake on, if you drive around with it off expect oil all over the rear of your engine bay as it will shoot out oil if you go wot or any where near wot.
That's what she said...
You need a special socket to install it with, which you can get at an autoparts store. When you put the new sensor on (before the new manifold), leave the socket over the sensor, it will protect it while you install the manifold. Most people break it off by hanging the brake booster line on it. Just be mindful that it's fragile and you should be fine.
Originally Posted by its turbo time
how about getting the broken one out? Any tips, its pretty much sheered off except these two yellow prongs sticking up.
Originally Posted by BLK02TA
Whats this special socket everyone speaks of? How can one avoid hanging up the line, is there an easy way to disconnect it?
not on mine
Originally Posted by reject
i thought GM had their engine's to not be able to turn on without having a signal from the oil pressure sensor, to protect itself from not "seeing" any oilpressure and running the engine "dry"
It really is not that big of a deal. Maybe because I am 6'4" I can easly reach back and put it in but the socket will make it easer. I think last time is used the same socket as the one for o2 sensor. any deep well socket will work.........
