to weld or not to weld
Old 04-05-2007, 10:19 PM
'01_z28's Avatar
Default to weld or not to weld
well i've finally got my complete exhaust in and i need some help. am i suppose to weld the tsp true duals to the headers or am i suppose to bolt it up some how.
Old 04-06-2007, 01:07 AM
That's what she said...
TheBlurLS1's Avatar
It should slip over the headers. You use band clamps to secure them. If they are welded, you'd have to cut/re-weld if you ever wanted to remove them. They should have come with all the necessary clamps, if not, you need to call TSP.
Old 04-06-2007, 10:11 AM
bigman's Avatar
You can clamp them, but they will most likely leak. Ive tried everything, and ended up needing to put flanges on the the collectors and tsp piping.
Old 04-06-2007, 10:15 AM
brad8266's Avatar
I like to weld a 3 bolt flange on the headers and x-pipe and just bolt it together, that way it is easy to remove. Slip fit FTL!!
