Which underdrive pulley will work with Double roller timing chain?
Well i've heard that some underdrive pulleys WILL not work with the double roller, so i was wanting to make sure before i bought one. So if you have a double roller chain then please enlighten me on what underdrive pulley you went with...
Thanks
B.J.
Thanks
B.J.
Had me worried. I just bought a slp pulley and ported pump and the dual chain and gears. All it says in the instructions is you may have to grind on the t-chain cover by the seal
