quick ory question about o2 sensors
installing an ory right now and there are no bungs for the o2 sensors. what should i do with the o2 sensors just unplug them and take them off ? thanks
Well you can do that but youll get an SES light for a bad cat. If you have to go to emissions this is a automatic fail. No emissions then dont worry about it, if you have emissions can either get a tune or 02 sims to fix that problem.
Hey ya'll the man said he didn't have ANY bungholes. You need to get the bungs welded in for your front sensers anyway because thats what tells the CPU how the cars running and if it needs to add more or less fuel to the engine. The rear O2s came be faked out by a O2 simulator or removed by your tuner . But you have to have the front ones.
