any how-to on Kmember installs?
i've been searching the forums but cannot find much information in Kmember installs. I ordered a UMI performance member and im curious whether i need to drop the entire motor to install the kmember or just the member itself ?
Ive swapped mine out with a Spohn one. You have to keep the motor supended and drop the k-frame, a-arms, and shock assembly. Then swap out the k-frame and put it all back on. It should come with instructions but I didn't use mine, it's really straight forward when you are under the car.
And it is 100 times easier with a lift. a driveway k-frame swap will suck.
not a problem because i have access to a lift. i was just wondering if there were any tips or tricks to swapping it out in case i get snagged up on something really dumb.
Of all time consuming jobs I've done, it was the easiest. It just took a while. You might want to have a couple buddies help you hold the new k-frame up when you go to bolt it in, because you have to line up like 8 points all at once.
But I didnt really have any stupid-easy fix moments the entire time.
