Car wont start off ignition
Well,
When I try to start the car with the key in the ignition, the car wont start. It has power to everything. I can hook up a remote starter directly off of the starter and it fires every time? So I'm at a loss... Anyone got an Idea as to where I need to start? Something I forgot to plug in? Clutch switch/sensor? Key resistor?
Is the engine turning over when you turn the key to the Start position ? or is it turning over but not starting ?
If it doesn't turn over.. then I would guess that your Ing to starter wire would be the 1st place to check again. it is the large purple wire. See if you are getting 12volts while the key is in the start position.
Next I would check the switch on the clutch pedal. Try bypassing the switch by disconnecting it and jumping the two connections.
There is not a whole lot to the starting system, Double check the fuses again.
