What the hell is going on here?????
I Washed Under The Car Lastnight And When I Was Done It Started To Misfire Bad . I Plugged In The Predetor To Check Out The Code And It Was A Misfire Po3oo And Then I Noticed The O2 Sensors One Was Reading 1105 Mv And One Was Jumping All Around 50mv - 960 Mv. Did I Just Get Something Wet And Need To Dry It Out Or What?
Probably got something wet that needs to dry... although it might get corroded after a while if it's an exposed wire or something of the like. That used to happen with my lt1 from time to time :-/
