Fast 90mm to stock maf
Restricted User
What kind of tube is everyone using. I installed the instake today and can not get the stock tubing to go around the TB.
Any suggestions or what part do I need?
This is a similar situation to what I had while putting the K&N FIPK on my Camaro with the SLP 85mm mass airflow sensor. The FIPK is made to work with the stock 75mm mass airflow sensor. Needless to say when I went to hook up the bellows, it was 10mm too small. There is a solution to fitting it correctly without having to cut anything or buying a bigger bellows (although I did have to buy one bigger holding clamp/worm clamp). The solution is to get a big bowl. Run the hottest water you can muster from your tap and place the bellows in the hot water for 2-3 minutes. This will make the rubber expand and become more pliable. Then I pulled out the bellows, stretched it open by hand as much as I could and quickly dried it off. It then fit over my SLP with just a little bit of effort.
You should be able to get away with the same technique with your bellows and 90mm throttle body. If hot tap water doesn’t work, try boiling water and stretching.
