Car is Slower with FAST 90, NW 90
Well kinda weird i previously trapped 117-118ish 11.90s-12.0s
Since then i added a fast 90mm intake/TB, intake previous was ls6 and stock tb, i took out the pacesetters and did qtp hvmc headers, i took out a qtp ypipe added a kooks, cause qtp was junk, ground clearance among other things. I added asp pulley, previous was stock, added poly motor mounts also.
well i go to the track in about the same DA/air quality and pop off a 12.17 @ 116 not to mention the 1/8mile speed was about 2-3mph lower
i know alot of you are going to say the tune, i agree, but i would have figured it run a little faster even with the tune it has. im thinking its running out of fuel up top, I still have the stock 26lb injectors, what do you think?
Add injectors, new tune ill hit 120mph?
Tech Resident
+1 on tune. i can pretty much guarantee your A/F is screwed up horribly. QTP's with HVMC's have been dyno-proven to add 8 peak hp on a mildly modified internals car.
i just went to the track last night and picked up two tenths with the fast 90/ptm 90 combo untuned also. went from 12.14 to 11.90 identical sixty foots. Hoping to get it tuned to see if I pick up anything else
