Service Vehicle Light?
I know that Service Engine Soon means that there is a problem and that a code has been set. I keep getting a Service Vehicle Light occassionally. How do I clear this. About a year ago I had it tuned with LS1 Edit when the LT's and catted Y were installed. Thanks.
chances are its the O2 sensor switching code... since you had headers installed.. its kind of common
if you dont have a code reader... you can take it to any autozone and use theirs for free and see what code is coming up... their code reader will also clear the Check engine light... at least this will give you the code to know what to look for... if it is the O2 codes.. you can try using the rear corvette O2 sensors "BOSCH 131111's" they seem to clear up that problem
