BIG Single Exhaust??
Im Considering runnin a single 3.5 on my car does anybody else run this or have something similar??? If so What muffler are you runnin and where is it mounted? Thanks For any help!
If you're going to bother redoing your whole exhaust, you are wasting your time by going with a single pipe setup. No matter how big you make the single exhaust it will never flow as well, sound as good, or make as much power as duals. Cars with 2 banks of cylinders should have 2 exhaust pipes for best performance, thats just the way it was meant to be.
I don't think a single pipe is a waste of time, if I'm not mistaken, a single 4" pipe has almost as much volume as two 3" pipes. It probably would weigh a little less than duals, and would look pretty cool too. You could do something similar to the SLP 2OTL, with the I pipe routed over the axle on the right side, entering the muffler in the standard location, and then exiting on the left.
http://video.ls1tech.com/video/D0A43...1EE65EE793.htm
Not the best sound, but gives you the idea.
Originally Posted by BLK02TA
I would definitely do something like that if i had a camaro!!
Originally Posted by xfactor_pitbulls
Really..............my last 4" out the back setup I built sounded badass through a dynatec split flow muffler. I also put down 460/410 through it. Only bitch I have about it is clearance in the tunnel and over the axle.
Bottom line is you can do a lot with a single Y-pipe exhaust, but its still a less than optimal setup for a V8 motor. The only reason F-bodies have a single y pipe exhaust is because it was cheaper to manufacture and fit on the car, not because of sound or performance.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Your last, my current.
Thats all well and good, but unless you install TD's and get it dyno'd, you still don't know if you would be making more power with that setup. Especially something like 3" duals. Any exhaust looks good until you do a direct comparison with a different setup.
How much less do you think a 4" single exhaust would be losing over a 3" true dual setup?
Bud, I have gone through atleast 5 totally different exhausts and have seen the changes on power throughout the rpm range. Nothing new there. You should be looking at it in terms of sq in of area. To which a single 4" is nearly as much as two 3". Its all about the merge as well. There are mostly junk y merges on these cars and you have to use the few that are the best. As in the flowmaster in particular.
There's a reason all high end sports cars come with dual exhaust with a crossover of either an X or H pipe. It's best for flow, exhaust velocity, and sound.
A true dual 3" system with an X-pipe will make more power, flow better, and have high exhaust velocities than your 4" y-pipe setup. Its a fact, physics are working against you. If you don't believe me than try it yourself, you will make more power and torque than you have now.
