New Kinsler Itb Manifold
Any News On The New Itb That Kinsler Is Developing For Ls Engine That Was Mentioned On Here A Few Months Ago In The Itb Thread. I Think Argon Z Was A Working On It.
There already seems to be a vertical stack model available, but the one being worked on was/is a cross-ram style for LS7 heads. There didn't seem to be much enthusiasm for it in this community, people were balking at the price. But to me, $3K to make a big cam drivable is not such a bad deal at all, compared to the $$ I just shelled out for an LS7 crate motor.
Originally Posted by 8ty8 LS1
would it benefit to have a cross ram type manifold using only 2 tb's? i've had some ideas of designing one. at least when i get out of school, that is.
The expense is beyond most people's budgets, but like many things if you can afford it the benefits are big. You can run a 250 @ .050 cam with small LSA, and still idle and drive great. Considering some folks ante up nearly $2k just for headers, this is actually pretty good value on a high dollar build. And it's not a ripoff - consider the fact that you're buying 8 precision machined throttle bodies instead of one, and you can see where the manufacturing costs come from.
Originally Posted by DONAIMIAN
Im not a fabricator, so the onlything that turns me off to it is no bolt on way to filter the air.
Originally Posted by Beast96Z
8 individual K&N's. Unless you can build a large box design to bolt to the plates, you'll end up hendering the possibilities of the intake. Building a large box with a huge filtering area really isn't an option in the F-body chasis, so i believe the 8 filters will work best. I plan to install the intake and buy the biggest/longest filters I can fit. I'm limited to 4"s in diameter because of the trumpet spacing, and I'm hoping I can fit a 5" to 6" long in there. Hopefully that will be enough for 1 cylinder.
Kinsler LS1/2/6 intake.....$10,000 Just spoke to them.
Harrop it is.
Have you measured to see how the Harrop will fit under the cowl?
Originally Posted by Quickin
The entire set-up, ready to bolt on and tune........
Harrop it is.
Harrop it is.
As for fitment, another member/shop owner posted picks of the Harrop in a TA. He said it fit fine. I figured it would from the measuments Harrop sent me.
Pics here: https://ls1tech.com/forums/showthrea...85#post5926285
I know Kinsler is a really great quality product but has anyone ever seen or delt with this ITB manifold. They claim to have a LS1 Intake but I have never seen it. The shop I work for just ordered one for a Ford 351W based engine we are building. They are MUCH cheaper than kinsler... at least for the FORD stuff.
http://www.imagineinjection.com/products.html
When I spoke with them (Kinsler) today they told me that one of their guys has one and its running on an LS1 perfectly. Street driven, very smooth. The engine was installed in a kit car.
Originally Posted by xfactor_pitbulls
Yeah I am sure they wouldnt be biased about their product. They would always be honest and tell you if they had problems with it.
