Expanding Exhaust
Old 05-03-2007, 01:59 PM
A-Dub's Avatar
Default Expanding Exhaust
Having trouble getting my Edelbrock Y to slip onto my collectors, its just slightly too small. None of the muffler shops around have an expander over 3". Any ideas on how to open these up just a bit? BTW, the Edelbrocks have 3.5" collectors
Old 05-03-2007, 03:06 PM
silent1's Avatar
A reducer:
http://store.summitracing.com/egnsea...115+4294865463
Old 05-03-2007, 03:10 PM
A-Dub's Avatar
I don't need a reducer, I just need a means for slightly expanding the Y pipe. If I was going from 3.5" to 3" I would use a reducer, but I am going 3.5 to 3.5
Old 05-03-2007, 03:50 PM
5_02ls1's Avatar
find a shop that works on big trucks most of them have the bigger expansion adapters
Old 05-03-2007, 04:38 PM
A-Dub's Avatar
Called a couple diesel shops already, none of them do exhaust work. They didn't have anyone to refer me to either
Old 05-03-2007, 04:46 PM
slowscott's Avatar
I had the same problem with my qtp headers and tsp duals. The only shop around me with a 3" pipe expander was OK 4WD. So maybe try an off road shop. If that doesnt work maybe you could rent a 2.5" expander (which seem to be more common) and jam something around it so it can open up a 3" pipe.
Old 05-03-2007, 05:11 PM
S1LV3R's Avatar
Maybe give Edelbrock a call? Their Y pipe should fit their headers. Sounds like maybe someone messed up at Edelbrock.
Old 05-03-2007, 06:04 PM
delsold's Avatar
how about the old scientific way....drape some ziplock bags full of ice around the collectors until they are real cold, and heat up the y pipe till its red hot
Old 05-03-2007, 06:22 PM
A-Dub's Avatar
I called Edelbrock, they were very friendly. They offered to have it shipped back, correct it and return it the same day they received it. I would prefer to have the car back up and running this weekend, but if I can't source a good way to do it, then I will take Edelbrock up on their offer.
Old 05-05-2007, 03:09 PM
ws6ed's Avatar
The very edge of the pipes on my edelbrock y were slightly bent in to less than 3.5" but 1/4" back they were more than wide enough. A quick trim and they slid on with no trouble at all.
Old 05-15-2007, 06:29 PM
JGA
JGA's Avatar
How's your ground clearance on that Y pipe. Thanks.
Old 05-16-2007, 08:12 AM
A-Dub's Avatar
I ended up using a piece of extra 3.5" pipe that came with the headers to wedge them open.
I welded in a pair of magnaflow 59959 cats, my driver's side clearance isn't all that hot. I have adjusted the fit a couple times and think its about as good as I can get it. Less than 6" for sure
Old 05-16-2007, 09:39 AM
JGA
JGA's Avatar
The reason I am asking is that I am looking at the same combo. Anything over 4" on the driver's side and I think you are doing well. Any chance of a photo with a soda can?
Thanks
Old 05-16-2007, 10:33 AM
A-Dub's Avatar
The Cat is 4" OD, Y pipe is 3" OD. If you didn't have the cat or even placed the cat elsewhere, you could probably tuck it up another 1/2"
Old 05-16-2007, 02:58 PM
JGA
JGA's Avatar
Not so bad, looks like you have about 4". The photo really helps. Thanks.
