LM resonator change to spiral flow process
I've decided to change the lm1 resonator to a spiral flow which I just got from a fellow member. I know a lot of people have done this and I'm sure it probably isn't very difficult, however, I want to make sure I'm not undertaking a task an exhaust shop would be better equipped to do.
Will the spiral flow fit right in without any modification once the resonator is removed? and can I reuse the same U-Clamps that came with the LM?
I'm just wondering if I'll run into sealing problems if I take this approach.
Thanks
Thanks
