Granatelli wires, why so much $$$, worth it?
Old 05-04-2007, 12:30 AM
LilJayV10's Avatar
Default Granatelli wires, why so much $$$, worth it?
I first heard about these wires in a mag, and we all know how reliable mags are now. Anyway, they said 10-15 RWHP gain. For wires thats nuts. I have done a lot of searching today and see that most people run either MSDs, Taylors and a few GMMP.
Resistance w/ the Granatelli wires is suppose to be .05 ohms.
Why does no one run these wires? Is it because they are over priced? Or are they really that much better but no one wants to spend the money.
I use to hear about 700 dollar tourqe convertors are great an no one would use them cause the price, then I bout one. Then I understood.
Thanks for any input.
Old 05-04-2007, 12:33 AM
Kage's Avatar
Cool
Cause MSD's just as good if not better.
Old 05-04-2007, 12:53 AM
Krab's Avatar
Unless your stock wires are shot or coming apart, I'd suggest concentrating the money you'd spend on these wires elsewhere...
Old 05-04-2007, 11:46 AM
LS69TA's Avatar
Its all marketing. If they said they wouldn't give any increase in HP nobody would buy them. I'd leave the stockers until they crap out on you. The $ can be better spent elsewhere.
Old 05-07-2007, 02:57 AM
Ripper415's Avatar
its been a while but i think the stock wires at like 500-600 ohms per foot and the msd are 40-50. the granatelli's are "supposed" to be under 1 ohm but also cost like 3 times as much as the msd's. the way i see it, getting wires that are 500+ ohms less is worth $60 but the 40 ohm difference between the msd and granatelli is certainly not worth the price difference.
Old 03-06-2008, 10:01 PM
camarojunky74's Avatar
sorry to say it but you are so wrong, granatellis come in under 1 ohm of resistance compared to msd being up in the 300's.
Old 03-06-2008, 11:02 PM
sroach20's Avatar
youre half wrong.
Granatelli 8mm Steel Solid Core Cable - 0.1 ohms
MSD 8.5mm Super Conductor - 71.6 ohms
Accel 8.8 300+ Ferro-Spiral Race Wire - 166.1 ohms
Jacobs Electronics EnergyCore 8.5mm - 178.3 oms
Taylor Spiro Pro 8mm Silicone - 301 ohms
Mallory Pro Sidewinder 8mm Silicone Suppression Wire - 313 ohms
Moroso Blue Maz Spiral Core 8mm - 661 ohms
Magnecor KV85 Competiton 2.5mm - 2053 ohms
Old 03-06-2008, 11:18 PM
ahhh you got me, damnit, well at least the whole truth comes out
Old 03-07-2008, 11:02 AM
JScamaro's Avatar
Originally Posted by sroach20
youre half wrong.
This is good info but in the end does it matter? Its only a spark plug wire. If your stock wires are good OP then reuse them. If they are messed up then I would buy a set of MSD's.
Old 03-07-2008, 11:13 AM
according to dyno tests my popular magazines the granatellis actually made horsepower, i will be testing the granatellis coming up here real soon
Old 03-07-2008, 08:28 PM
sroach20's Avatar
i like the msd boots with headers.
Old 03-07-2008, 09:19 PM
a-low's Avatar
youre half wrong.
What about Crane Cams wires?
Old 05-30-2008, 10:41 AM
wtfx100's Avatar
Updates?
Old 05-30-2008, 11:24 AM
billyb's Avatar
youre half wrong.
but !!!!!!!!! steel solid core will play havoc with your radio, engine noise.
Old 05-30-2008, 08:04 PM
Originally Posted by wtfx100
Updates?
yeah no noticeable improvements in mph or hp. i need to take it to a dyno and test them there
Old 05-31-2008, 12:18 PM
mycamaroSS's Avatar
these companies can get away with anything, saying you can get xxrwhp, their full of ****. It all depends what you put in your motor and the tune
Old 05-31-2008, 12:33 PM
hlaalu's Avatar
my $70 msd's work good for me!
Old 05-31-2008, 01:07 PM
mycamaroSS's Avatar
yea those are what im getting
Old 05-31-2008, 01:09 PM
Mike@ZMS's Avatar
youre half wrong.
I do believe that all of these resistance ratings are rated per foot. On an LS1, your talking about actual resistance being half of the rated resistance.
Im a big fan of swapping out the stockers, but the MSD's are probably as good as it gets, unless you want to take the time to ground each individual wire with some Nology wires. Probably no gains in power with the Nologys over the MSD's, but I have had 3 MSDs come apart on me in the past year. Getting kind of sick of it, but now I have lots of spare wires at least.
Quick Reply: Granatelli wires, why so much $$$, worth it?
