Ac blows through the bottom after ls6 intake install.
Well I installed a ls6 intake and pacesetter headers on my 98 Camaro, which made a big difference, my question is does anybody have a picture of where I may have messed up my ac, my ac still blows ice cold air, but it blows it thru the bottom and not through the vents, so where did I messed up.
I have the same exact issue....according to the Write ups by other members there should be one vacuum line left over that needs to be plugged when removing AIR/EGR on these cars. I plugged the only vacuum line back there left over and now that its back together the A/C+Heat blows out the defrost and floor vents but won't switch to the dash vents.
I am having the same problem, but have a number of loose hoses from when I removed my EGR and AIR.
I think I have located the vaccum line that runs out of the PCM wireloom: it appears to have two nipples, one is much longer than the other. Do you know which one goes into the back of the intake?
I will try to get pics up tomorrow...but any advice is much appreciated!
Alright, I think I have an idea where it inlet is located at the back of the intake. I felt around for awhile and found what appears to be a nipple pointing to the passenger side as described above.
My next question, is which is the proper vaccum tube to plug into it? I have a few loose ones from when I removed the AIR and EGR. Please take a look at the pics, and if you can, let me know:
Vaccum Tube 1
Vaccum Tube 2
As you can see in picture 2, there are two options. A tube that is much longer than the other. These tubes appear to be coming out of the PCM wireloom as described above, so I am thinking it is one of these that plugs into the back of the intake.
If so, is it the longer or shorter one that is supposed to plug in??
Thanks
Vaccum Tube 1
Vaccum Tube 2
Thanks
