header install finished questions left
here are a few pix of the install. Take a look and let me know if it looks ok. I have to clean up a little gasket of the pipes and so on. Also the pix of the drivers side cutout and how low it is to the ground it's only about 2 inches form the ground. Is this normal or is something not right making it lower than normal.
I cant really give you much help, but that does look a little low. However based on your sig, you are running the pro kit which will obviously affect ground clearance. I would just recommend that you dont go over any huge speedbumps or you'll find your cutout behind your car in three chunks. You could try to move it to somewhere on the I pipe if you could find a spot for it? Good luck!
